Read data from the website using ESP8266
Dear All
Dear All I have a website which is running on wamp server and it is working
I have written a program for ESP8266 to read the data from the website and it is working and connect with my website run on the wamp sever
My website have four variables
Ex strText1, strText2 , strText3 , strText4
Each veritable have a value
So need to read the value assigned to the variable
I used following command to read the website
client.println("GET /index.php HTTP/1.1");
Using above GET method it is showing all of the website elements
please advice how can i use the correct GET URL to read the correct variable value
Please advice
Thanks in advance
A "web site" is what browser renders after executing a script on the server. You do NOT have a website running on a server.
Using that GET request, the script, index.php, is executed, and the server sends the output back to you.
Something happens with that data. Something the code that you did not post does.
Without knowing anything about index.php, we can't.
PaulS:
I'll have to disagree on that one.
A website, also written as web site, is a collection of related web pages, including multimedia content, typically identified with a common domain name, and published on at least one web server.
source wikipedia
dataType : "json", //We will be requesting data in JSON format
timeout : 10000, //this will cancel the request if it has not received a reply within 10 seconds.
success: function(data){
strText1,strText2,strText3,strText4 = "";
stSpoon1,stSpoon2,stSpoon3,stSpoon4="";
nocache = "&nocache=" + Math.random() * 1000000;
var request = new XMLHttpRequest();
strText1 = "&txt=" + document.getElementById("order_form").List1.value + "&end=end";
strText2 = "&txt=" + document.getElementById("order_form").List2.value + "&end=end";
strText3 = "&txt=" + document.getElementById("order_form").List3.value + "&end=end";
strText4 = "&txt=" + document.getElementById("order_form").List4.value + "&end=end";
if(List1.value=="1Spoons" || List2.value=="1Spoons" || List3.value=="1Spoons" || List4.value=="1Spoo
PA3040:
I have no idea what this gibberish is supposed to mean. It is NOT a reply to "what does your index.php file look like".
Dear PaulS
I am sorry the post was missed some part
By mistake it is showing index.PHP and It should be Order.PHP
My Order.PHP codes have more than 900 words so this forum does not allow to post codes more than 900 words
Please advice to attached the cods
thanks in advance
Use the Reply button, NOT the Quick Reply field. When you do that, there is an Additional Options link at the bottom of the text entry window. Click that link, and you can add attachments to your post.
It might be easier to write separate php scripts to extract the 4 interesting bits of data, and then make 4 GET requests. It depends on whether you are more familiar with Arduino programming or PHP development.
