Read data from website from ESP client
Dear Aii
I configured my ESP 8266 12E as a client to connect my hotspot router home page 192.168.0.1
I connected my ESP to serial monitor
Serial monitor is showing connected and IP also released
But it does not receive any data from page
Following are the ESP client codes
#include <ESP8266WiFi.h>
/*use this macro to get into debug mode; comment it if the ESP module is connected to the arduino*/
#define DEBUG_MODE 1
const char* ssid = "SSID";
const char* password = "pasword";
const int websitePort = 80;
const char* host = "192.168.0.1";
  delay(10);
  // Connect to WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  delay(300);
  WiFi.begin(ssid, password);
    Serial.print(".");
  delay(300);
  Serial.println("");
  Serial.println("WiFi connected");
  // Print the IP address
  Serial.println("");
  Serial.println("IP address: ");
  Serial.print("connecting to ");
  Serial.println(host);
  WiFiClient client;
  if (!client.connect(host, websitePort)) {
    Serial.println("connection failed");
    return;
  while (!client.available()) {
    delay(1);
  // Read the first line of the request
  String request = client.readStringUntil('\r');
  Serial.print("Received: ");
  Serial.println(request);
  client.flush();
  String spoons;
Please advice
Thanks in advance
You need to issue an http get (or post). Have a look at an example e.g. https://learn.adafruit.com/adafruit-huzzah-esp8266-breakout/using-arduino-ide#connecting-via-wifi
  String spoons;
What is this for?
In setup(), why do you define an instance of WiFiClient that you never use?
