Read ds1820 temp sensor by ID
I work on a project where I need to read 10 temp sensors like ds1820. I used this code for get sensors id's
/* YourDuino Example: Find Address of a DS18B20 Temperature Sensor
 Cut and paste the address to a text file for later use.
 V1.1 01/17/2013
 Questions: terry@yourduino.com
 Connections:
 DS18B20 Pinout (Left to Right, pins down, flat side toward you)
 - Left   = Ground
 - Center = Signal (Pin 2):  (with 3.3K to 4.7K resistor to +5 or 3.3 )
 - Right  = +5 or +3.3 V
 This sketch looks for 1-wire devices and  prints their addresses (serial number)
 to the Serial Monitor in a format that is useful in Arduino sketches.
 Based on example at:
 http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
/*-----( Import needed libraries )-----*/
#include <OneWire.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define SENSOR_PIN 3  // Any pin 2 to 12 (not 13) and A0 to A5
/*-----( Declare objects )-----*/
OneWire  ourBus(SENSOR_PIN);  // Create a 1-wire object
void setup()  /****** SETUP: RUNS ONCE ******/
  discoverOneWireDevices();  // Everything happens here!
}//--(end setup )---
void loop()   /****** LOOP: RUNS CONSTANTLY ******/
  // Nothing happening here
/*-----( Declare User-written Functions )-----*/
void discoverOneWireDevices(void) {
  byte i;
  byte present = 0;
  byte data[12];
  byte addr[8];
  Serial.print("Looking for 1-Wire devices...\n\r");// "\n\r" is NewLine
  while(ourBus.search(addr)) {
    Serial.print("\n\r\n\rFound \'1-Wire\' device with address:\n\r");
    for( i = 0; i < 8; i++) {
      Serial.print("0x");
      if (addr[i] < 16) {
        Serial.print('0');
      Serial.print(addr[i], HEX);
      if (i < 7) {
        Serial.print(", ");
    if ( OneWire::crc8( addr, 7) != addr[7]) {
      Serial.print("CRC is not valid!\n\r");
      return;
  Serial.print("Done");
  ourBus.reset_search();
  return;
//*********( THE END )***********
and this code for read temperatures
/* YourDuino TEST: Temperature Sensor DS18B20
 *  V1.2 08-26-2016
- Connect cable to Arduino Digital I/O Pin 2
terry@yourduino.com */
#include <DallasTemperature.h>
/*-----( Declare Constants )-----*/
#define ONE_WIRE_BUS 3 /*-(Connect to Pin 2 )-*/
/* Set up a oneWire instance to communicate with any OneWire device*/
OneWire ourWire(ONE_WIRE_BUS);
/* Tell Dallas Temperature Library to use oneWire Library */
DallasTemperature sensors(&ourWire);
/*-----( Declare Variables )-----*/
void setup() /*----( SETUP: RUNS ONCE )----*/
/*-(start serial port to see results )-*/
Serial.println("YourDuino.com: Temperature Sensor Test Program");
Serial.println("Temperature Sensor: DS18B20");
/*-( Start up the DallasTemperature library )-*/
sensors.begin();
}/*--(end setup )---*/
void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
Serial.print("Requesting temperature...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
Serial.print("Device 1 (index 0) = ");
Serial.print(sensors.getTempCByIndex(0));
Serial.println(" Degrees C");
delay(5000);
}/* --(end main loop )-- */
/* ( THE END ) */
But how can I request temperature for a specific sensor id ?
Thanks in advance
if you look at
DallasTemperature.h
you will see there is a method
bool requestTemperaturesByAddress(const uint8_t*);
Stupid me...
Thanks a lot
