Hi. I configured an arduino nano to read an encoder in pin 2 and 3 with interrupts and show the value on a 4 digit display using TM1637 library and it worked fine.
But today I tried to change the display to a MAX7219 (LedControl lib) and now it loses counts and I cannot find the source of the problem.
Below the code.
pin 11 is connected to the CLK(13)
pin 10 is connected to LOAD(12)
LedControl lc=LedControl(12,11,10,1);
const byte encoderPinA = 2;//outputA digital pin2
const byte encoderPinB = 3;//outoutB digital pin3
volatile int count = 0;
int protectedCount = 0;
int previousCount = 0;
int showit = 0;
#define readA bitRead(PIND,2)//faster than digitalRead()
#define readB bitRead(PIND,3)//faster than digitalRead()
lc.shutdown(0,false);
/* Set the brightness to a medium values /
lc.setIntensity(0,5);
/ and clear the display */
lc.clearDisplay(0);
pinMode(encoderPinA, INPUT_PULLUP);
pinMode(encoderPinB, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(encoderPinA), isrA, CHANGE);
attachInterrupt(digitalPinToInterrupt(encoderPinB), isrB, CHANGE);
noInterrupts();
protectedCount = count;
lc.setDigit(0,3,(showit / 1000),false);
lc.setDigit(0,2,((swowit / 100) % 10),false);
lc.setDigit(0,1,((showit / 10) % 10),false);
lc.setDigit(0,0,(showit % 10),false);
delay(100);
interrupts();
if(protectedCount != previousCount) {
showit = protectedCount;
previousCount = protectedCount;
void isrA() {
if(readB != readA) {
count ++;
count --;
void isrB() {
if (readA == readB) {
count ++;
count --;
