Read ethernet subnet mask and gateway
I am using a Freetronics Etherten (Arduino uno compatible with ethernet shield) and Arduino 1.01 IDE with the standard ethernet library.
I have got to the point where I can connect my shield to the network and obtain an address via DHCP and can print my IP address to an LCD.
I also wish to print to LCD the subnet mask and default gateway obtained from DHCP. I can find no information on how to achieve this.
Is this at all possible with the standard ethernet library or do I need to modify the ethernet library or use a different one.
Thanks,
Don =)
Here are the network settings you can access:
IPAddress localIP();
IPAddress subnetMask();
IPAddress gatewayIP();
IPAddress dnsServerIP();
Access them like
Serial.println(Ethernet.gatewayIP());
Thanks heaps, that has worked a treat.
