I am trying to read a RFID tag and compare the RFID Number with a array which have already there. In my code, the comparing is not working properly. It always gives output as both 'Found' and 'Not found' . Can any one help me on this. The two RFID numbers that I want to read are: 37376B34 and 7AA29B1A. These two are only for the testing. I'm going to store about 20 RFID numbers in the array and check.
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
int readsuccess;
byte readcard[4];
char str[32] = "";
String StrUID;
char* myTags[] = {"9FF4375C","37376B34","7AA29B1A","1B7D5223","9FF4375C" };
Serial.begin(9600); // Initialize serial communications with the PC
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
readsuccess = getid();
if(readsuccess){
Serial.println(StrUID);
for (int i = 0; i < 5; i++) {
if (StrUID == myTags[i]) {
Serial.println("Found");
return;
else{
Serial.println("Not Found");
int getid(){
if(!mfrc522.PICC_IsNewCardPresent()){
return 0;
if(!mfrc522.PICC_ReadCardSerial()){
return 0;
for(int i=0;i<4;i++){
readcard[i]=mfrc522.uid.uidByte[i]; //storing the UID of the tag in readcard
array_to_string(readcard, 4, str);
StrUID = str;
mfrc522.PICC_HaltA();
return 1;
void array_to_string(byte array[], unsigned int len, char buffer[])
for (unsigned int i = 0; i < len; i++)
byte nib1 = (array[i] >> 4) & 0x0F;
byte nib2 = (array[i] >> 0) & 0x0F;
buffer[i*2+0] = nib1 < 0xA ? '0' + nib1 : 'A' + nib1 - 0xA;
buffer[i*2+1] = nib2 < 0xA ? '0' + nib2 : 'A' + nib2 - 0xA;
buffer[len*2] = '\0';
