Hi All, i know this subject has been opened a lot, but appreciate your support again.
i need to input around 1000 values from a text file, and read it by the Arduino Due board as variables.
values inside the text file can be separated in any way you want.
need the basic code please
other question, what is the best way to connect the board to the computer, can we still use the direct USB to Arduino port?
is this what you mean when you say Serial port?
last question
can we plug in anyway an SD card with a text file on it directly into any arduino board?
which board can give you the maximum digital ports? what is the maximum number?
thanks again guys, appreciate your support.
