Read ground signal from car switch with Arduino digital pin
Hi guys,
How can I read a ground signal from one of my car’s switches using Arduino’s digital pin?
Thank you.
Just a ground, and no voltage? You can configure the pin as INPUT_PULLUP and connect it directly.
If it's already hooked-up to something else in the car, it's probably 12V when the switch is turned off. Check it with a voltmeter and/or to be extra-safe, use a [u]protection circuit[/u] (a diode and resistor). Or, use a [u]voltage divider[/u] (2 resistors). But but with a voltage divider, still use the protection diode to protected against unexpected voltage spikes.
I've already solved this issue. Thank you.
Thanks for not sharing ;)
