Hi guys
I try to read led status from hc05 module and i write code to read status led2 pin
from hc05 by connect the led2 pin from hc05 to pin2 in my arduino nano and make inturrupt in pin2 in nano
to read the seqane of flashing if slow or fast
iknow if status of module pairing or not pairing from no of flashing if small than 4 the state is unparing but if mor than 4 its not pairing
so that code working fine put my problem is if i make connection between 2 blutooth module
if iam go away by any one of them or disconnect power of any of them
the led sequans of another hc05 led2 Its go fast
but if iconnect hc05 to mopile phone first the hc05 paired and led flashing slow
but if iam disconnect my bluetooth from my mobile or iam go away by phone or powered off my phon
the hc05 not unparing and the led flashing stell flashin slow as pairing
also status check in at command stell pairing
the module goes as hanging also iam trayng every thing i know like change the module by another but not solve this problem so thanks for any idea
My main problem the hc05 not unbairing from mobile connection when iam close bluetooth in my phone
The status led not plinking fast and really the module run as pairing
you need to write code same is you wrote for connection . so write the code for if there is no serial.available(). then your function you want write that ...
