Read IMU Data
Hi all
I bought an Arduino Uno and I have a Sparkfun IMU 9DOF Razor. I already managed to connect the IMU directly to my computer and read data (over Arduino IDE using the tu-berlin firmware https://dev.qu.tu-berlin.de/projects/sf-razor-9dof-ahrs/wiki/Tutorial, which works perfectly). Now I tried to let my Uno read the same data. I tried it with the following code
  Serial.begin(57600);
  if(Serial.available()) {
    Serial.print(Serial.read());
however, I just get "random" two digit number and then again a new line. Can someone tell me how to "correctly" read the IMU data? This is how i usually get the data when directly connecting the IMU with my PC
YPR=-155.73,-76.48,-129.51
High regards and many thanks R
RReguera: ``` void setup() {   Serial.begin(57600); }
void loop() {   if(Serial.available()) {     Serial.print(Serial.read());   } }
Use Serial.write() instead of Serial.print().
Dear Sir,
You made my day! I salute you!
Many thanks
