Read in 10-bits Magnetic Encoder AEAT-6010-A06 into Arduino Uno
Dear members,
for a school project I have to implement a 10-bits magnetic encoder on a plant.
To explain the plant, I will give you a similar example: Arduino + Matlab: Controlador PID - test 1 - YouTube
I have to inplement PID controle with LabVIEW and an Arduino Uno..
Instead of the potentiometer to check the angle of the bar, and use PID depending on the angle, I now have to use a 10-bits magnetic encoder.
The following one: AEAT-6010-A06 10-bits Magnetic Encoder
Link tot the datasheet: http://www.avagotech.com/docs/AV02-0188EN
The AEAT-6010 magnetic angular based rotary detector uses a serial data stream and clock to be able to read out the absolute position in digital form.
The CLOCK and DATA signals are transmitted according RS-422 standards.
About the code:
As you can see in the characteristics in datasheet I have to "produce" a 10 times "HIGH" and "LOW" signal for the CLOCK.
I also have to watch the delay times which are given in the datasheet and making the Chip select and CLK high as given in the characteristics.
I have allready made the following code, but on the Serial Monitor I only get a "1" out..
My pin connection is the following one:
1: VDD (5V supply voltage): 5V power supply Arduino
2: CSn (Chip select): Digital output 4 Arduino
3: VSS (GND): GND Arduino
4: CLK (Serial clock-input): Digital output 7 Arduino
5: DO (Serial Data-Output): Digital output 8 Arduino
Does anyone has some experience with reading this kind of sensor into the Arduino?
I would appreciate your help a lot!
// Read in 10-bits Magnetic Encoder AEAT-6010-A06  into Arduino Uno
// RobinL
// Declarate
const int CSn = 4; // Chip select
const int CLK = 7; // Clock signal
const int DO = 8; // Digital Output from the encoder which delivers me a 0 or 1, depending on the bar angle..
unsigned int sensorWaarde = 0;
void setup(){
	//Fix de tris
	pinMode(CSn, OUTPUT);
	pinMode(CLK, OUTPUT);
	pinMode(DO, INPUT);
	//Let's start here
	digitalWrite(CLK, HIGH);
	digitalWrite(CSn, HIGH);
	sensorWaarde = readSensor();
	delayMicroseconds(1); //Tcs waiting for another read in
unsigned int readSensor(){
	unsigned int dataOut = 0;
	digitalWrite(CSn, LOW);
	delayMicroseconds(1); //Waiting for Tclkfe
	//Passing 10 times, from 0 to 9
	for(int x=0; x<10; x++){
		digitalWrite(CLK, LOW);
		delayMicroseconds(1); //Tclk/2
		delayMicroseconds(1); //Tdo valid, like Tclk/2
		dataOut = (dataOut << 1) | digitalRead(DO); //shift all the entering data to the left and past the pin state to it. 1e bit is MSB
	digitalWrite(CSn, HIGH); //
        Serial.println(dataOut);
	return dataOut;
Best regards,
RobinL
Hi RobinL,
May be too late, but I tested your code with my AEAT-6012-A06 (notice the 12-bit resolution, one digit change in the code) on an Arduino Nano and it had worked for me perfectly after I added Serial.begin(115200) into your setup. Great Code!
Regards,
Linarism
Edit:
P.S.
Did you manage to find a 5-pin PicoBlade connector for your encoder?
Hi Linarism, I have a couple of connectors. I can send you one. Please can you share your complete source code?
Thanks
Lynass
Hey lynass,
Here's the slightly modified code I used to work with the 12-bit variant of this encoder. I'm going to write a simple library for talking to these encoders as I will need to use it for reading many of them from one controller soon. Hopefully I'll be able to use it over hardware serial.
// Read in 12-bits Magnetic Encoder AEAT-6012-A06  into Arduino Nano
// RobinL modified by linarism
// Declarate
void setup(){
  Serial.println("Hello World!"); //send sample text to monitor for debug
  //Fix de tris
  pinMode(DO, INPUT);
  //Let's start here
  //Passing 12 times, from 0 to 11
  for(int x=0; x<12; x++){
  digitalWrite(CSn, HIGH); //deselects the encoder from reading
  return dataOut;
