Hi Group,
It looks that the only way to get a single key decoded is hitting the return kley.
Is there a way to get a single key, for example the home oresc key, so I can act on it??
Harry
Hi Group,
Harry
gharryh:
Hi Group,
Is there a way to get a single key, for example the home oresc key, so I can act on it??Harry
Perhaps you left out some pretty important information????
Paul
Consider dropping using the serial monitor
Yes, drop the serial monitor, where you pay for the ability to edit your keystrokes before "sending them along" with the button or carriage return.
--> And pick one of any number of serial-port terminal applications google might turn up.
I use CoolTerm, simple, free and easy to use. When I care about seeing each keystroke IRT.
a7
OK maybe some explanation can help.
I want move some servo's using the up/down and left/right keys from my laptop
And hitting the home-key would move both servo's to the 0 pos.
Harry
Use a proper terminal emulator.
Putty, TeraTerm ...
Yes use TeraTerm or CoolTerm and then use this code on the Arduino side
// readOneChar.ino
// Reads one char cmds from Serial
// https://www.forward.com.au/pfod/ArduinoProgramming/SoftwareSolutions/index.html
// Pros: Extremely Simple, Non-blocking and Robust
// Cons: Nothing really. You can do a lot with one char cmds (A..Z,a..z,0..9) plus symbols
for (int i = 10; i > 0; i--) {
Serial.print(' '); Serial.print(i);
char c = Serial.read(); // note read() returns an int, char c = converts it to a char
if (c != -1) { // read() return -1 if there is nothing to be read.
// got a char handle it
Serial.println(c);
drmpf:
Thanx but this code depends still on a return after a single character
gharryh:
Not if you use a terminal emulator.
gharryh:
Nope. It is a serial port. It doesn't care.
Both TeraTerm and CoolTerm, by default, send the keypress as soon as you press it.
This results in a lot of very small msgs (one char at a time) so they both have options to 'delay' sending chars to allow them to 'collect' a few to send at once. BUT by default these delays are set to 0 or not enabled so EACH keypress is sent as soon as you hit the key.
Note: On the Arduino receive side you have to use Serial.read() and look at each key. All the other Serial.readxxx methods will sit and wait for 1sec to see if any more chars arrive before allowing the rest of the code to continue.
Serial.readStringUntil('\n') and Serial.readBytesUntil(... , '\n') return when they see the newline so if you use those in your Arduino code, it looks like you need to hit Enter to get the message through, but that is your Arduino code getting in the way.
See my tutorial Arduino Serial I/O for the Real World for more details about using real time Serial.
But for your case the above simple Arduino code and TeraTerm or CoolTerm is all you need
