Read Input 4-10 mA
Hi all
i have a problem to read input 4-20 mA in my loop calibrator (fluke) show 15,6 mA then serial read arduino show 15,0 this my sketch
float analog=A0; float sen=0; float lop=0;
void setup() { Serial.begin(9600); }
void loop() { sen = analogRead(analog); lop = map(sen,205,1023,5,20); Serial.println(lop,DEC); Serial.println("\n"); delay(500); }
any suggestion ??
  lop = map(sen,205,1023,50,200);
  Serial.println(lop/10.0,1);
As knut_ny has pointed out (without any explanation), you are throwing away the decimal place in your map function (it only does integer maths). Map it to a larger range then divide later or just do the map function yourself using floating point values.
