Read inputs from an instrument connected with ethernet using arduino sheild
Hello all,
I have a question,
I know how we can read data from an analog pin and flash it to a website using arduino.
But I want to connect a device (which is only capable to send data through Ethernet) with arduino and take the input.
In fine, please give a solution / code of how to get data as an input from the ethernet port to the arduino sheild/arduino-which there after I can see from the serial port.
Thanks and regards,
Jayanta
jayantaD:
You probably want to open a TCP socket between a Server and Client, look at the Ethernet Library
Yours,
TonyWilk
