Read IR signal at the arduino
Hello everyone,
I'm trying to make integration to my project with the following components:
*SR-04 X4 to detect distance
*Tsop receiverX3
*Dc motor driver X4
When i read the IR signal with my receiver with this program I see that the receiver receives the signal from the transmitter successfully using this program:
int frontReceiver = 15; //Read from the front receiver
int rightReceiver=16;
int leftReceiver=14;
#define LED_FRONT_GREEN 52
#define LED_RIGHT_RED 53
#define LED_LEFT_YELLOW 51
  pinMode(LED_FRONT_GREEN,OUTPUT); //LED FRONT
  pinMode(LED_RIGHT_RED,OUTPUT); //LED RIGHT
  pinMode(LED_LEFT_YELLOW,OUTPUT); //LED LEFT
  pinMode(leftReceiver,INPUT);
  pinMode(frontReceiver, INPUT);
  pinMode(rightReceiver,INPUT);
  int ReceiverF = digitalRead(frontReceiver);
  if(ReceiverF==0)
     digitalWrite(LED_FRONT_GREEN,HIGH);
     delay(100);
     digitalWrite(LED_FRONT_GREEN,LOW);
     delay(100);
  int ReceiverR=digitalRead(rightReceiver);
   if(ReceiverR==0)
     digitalWrite(LED_RIGHT_RED,HIGH);
     delay(100);
     digitalWrite(LED_RIGHT_RED,LOW);
     delay(100);
  int ReceiverL=digitalRead(leftReceiver);
     if(ReceiverL==0)
     digitalWrite(LED_LEFT_YELLOW,HIGH);
     delay(100);
     digitalWrite(LED_LEFT_YELLOW,LOW);
     delay(100);
But when i am trying to upload the program that includes all the components the reading from the receivers is really bad.
I tried to decrease the delay in my program but it didn't help.
Here is my program that make the reading from the receivers bad.
#include <Servo.h>
#include<NewPing.h>
Servo myservo;
#include <AFMotor.h>
#define MAX_SPEED 255
#define SLOW_SPEED 255
#define MAX_DISTANCE 400
#define echoPinLeft 30 //LEFT ULTRASONIC
#define trigPinLeft 31 //LEFT ULTRASONIC
#define echoPinFRONT 47 //FRONT ULTRASONIC
#define trigPinFRONT 46 //FRONT ULTRASONIC
#define echoPinRIGHT 23 //RIGHT ULTRASONIC
#define trigPinRIGHT 22 //RIGHT ULTRASONIC
AF_DCMotor Motor1(1,MOTOR12_64KHZ);
AF_DCMotor Motor2(2,MOTOR12_64KHZ);
AF_DCMotor Motor3(3,MOTOR12_64KHZ);
AF_DCMotor Motor4(4,MOTOR12_64KHZ);
NewPing sonarLEFT(trigPinLeft, echoPinLeft, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
NewPing sonarFront(trigPinFRONT, echoPinFRONT, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
NewPing sonarRIGHT(trigPinRIGHT, echoPinRIGHT, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
int flag=0;
void drive_forward();
void stop_driving();
void drive_fast();
void drive_right();
void drive_left();
void drive_back();
void rotateRight90();
void lookLeftservo();
void lookRightServo();
void turnOnLeftLed();
int ReadDistanceFront();
int ReadDistanceLeft();
int ReadDistanceRight();
void avoid_obstacle();
void turnORightLed();
void turnOnLedFront();
void IR_signal();
pinMode(trigPinLeft,OUTPUT);
pinMode(echoPinLeft,INPUT);
pinMode(trigPinFRONT,OUTPUT);
pinMode(echoPinFRONT,INPUT);
pinMode(trigPinRIGHT,OUTPUT);
pinMode(echoPinRIGHT,INPUT);
//myservo.attach(22);
IR_signal();
void IR_signal()
int distanceFront=ReadDistanceFront();
int distanceLeft= ReadDistanceLeft();
int distanceRight=ReadDistanceRight();
int counter=0;
if((distanceFront<70||distanceLeft<70||distanceRight<70) && (ReceiverF==LOW||ReceiverR==LOW ||ReceiverL==LOW) )
stop_driving();
Serial.println("at the destination");
else if (ReceiverF==LOW &&distanceFront>70) //No obstacle FRONT
turnOnLedFront();
drive_forward();
Serial.println("no obstacle, drive forward");
else if (ReceiverR==LOW && distanceRight>70) //NO obstacle Right
turnORightLed();
rotateRight90();
Serial.println("rotate right");
else if (ReceiverL==LOW &&distanceLeft>70) //NO obstacle LEFT
turnOnLeftLed();
rotateLeft90();
Serial.println("rotate left");
return;
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
drive_fast();
Motor1.run(FORWARD);
Motor2.run(FORWARD);
Motor3.run(FORWARD);
Motor4.run(FORWARD);
void drive_fast()
Motor1.setSpeed(MAX_SPEED);
Motor2.setSpeed(MAX_SPEED);
Motor3.setSpeed(MAX_SPEED);
Motor4.setSpeed(MAX_SPEED);
void drive_slow()
Motor1.setSpeed(SLOW_SPEED);
Motor2.setSpeed(SLOW_SPEED);
Motor3.setSpeed(SLOW_SPEED);
Motor4.setSpeed(SLOW_SPEED);
return;
void stop_driving()
Motor1.run(RELEASE);
Motor2.run(RELEASE);
Motor3.run(RELEASE);
Motor4.run(RELEASE);
void drive_left()
drive_slow();
Motor2.run(BACKWARD);
Motor4.run(BACKWARD);
drive_slow();
Motor1.run(BACKWARD);
Motor3.run(BACKWARD);
stop_driving();
void rotateLeft90()
drive_slow();
stop_driving();
void drive_right()
drive_slow();
return;
void drive_back()
drive_fast();
delay(30);
int sum=0;
int distance=0;
for (int i=0;i<10;i++)
distance=sonarLEFT.ping_cm();
sum=sum+distance;
distance=sum/10;
if (distance==0)
distance=5000;
return distance;
delay(30);
int distance=0;
int sum=0;
distance=sonarFront.ping_cm();
sum=sum+distance;
distance=sum/10;
if (distance==0)
distance=5000;
return distance;
delay(30);
int distance=sonarRIGHT.ping_cm();
int sum=0;
sum=sum+distance;
distance=sum/10;
if (distance==0)
distance=5000;
return distance;
What are you using for power? You've got a lot of loads there. Normally software doesn't just break, but hardware does.
Now I'm using the power from the USB in my laptop.
Not sure how this relates to Covid-19 Projects, hence moved to a more suitable location on the forum.
Why do you post one code using code tags (great) and the other one without (not so great); please edit your opening post and apply code tags.
You've not got enough mA @ +5VDC from the USB port. The card max is 200mA and your motors are goining to burn all of that & more. Get a real DC power supply and run everything off THAT. Put a switch in your USB cable's RED wire so the external PS doesn't try to bring up the PC.
