Hi all,
I am using a esp32-cam sketch (this one), and it works fine in my environment (IDE ver 1.8.16, esp32 boards ver 2.0.1, AI-Thinker esp32-cam), and now I want to modify the sketch to do a few extra features.
So far I have managed to save the camera captured jpg files in LittleFS file system, and also to read those files and send them to a ftp server. The ftp part of my code (after ftp login) is:
path = (String) "image.jpg"; // test file
fullPath = (String) "/" + path ;
const char * ftpFile = path.c_str();
const char * FS_file = fullPath.c_str();
File file = LittleFS.open(FS_file);
if (!file) {
Serial.println("LittleFS.open failed");
return;
ftp.InitFile("Type I"); // bin
ftp.NewFile(ftpFile);
Serial.printf("writing file: %s \n", ftpFile);
while (file.available()) { // Create and fill a buffer
unsigned char buf[1024];
file.read(buf, sizeof(buf));
ftp.WriteData(buf, sizeof(buf));
ftp.CloseFile();
file.close();
It works well, and I think maybe I can re-use some of that code in my next challenge, which is to read a jpg file from LittleFS and feed a HTTP "handler" that would display the image just like the original "capture handler" displays the image taken with the camera.
I find the HTTP coding rather difficult to understand, so I hope some of you can help me with this last part. Here is the original capture handler (works fine):
static esp_err_t capture_handler(httpd_req_t *req) {
fb = NULL;
esp_err_t res = ESP_OK;
Serial.println("Capture Requested");
fb = esp_camera_fb_get();
if (!fb) {
Serial.println("CAPTURE: failed to acquire frame");
httpd_resp_send_500(req);
if (autoLamp && (lampVal != -1)) setLamp(0);
return ESP_FAIL;
httpd_resp_set_type(req, "image/jpeg");
httpd_resp_set_hdr(req, "Content-Disposition", "inline; filename=capture.jpg");
httpd_resp_set_hdr(req, "Access-Control-Allow-Origin", "*");
if (fb->format == PIXFORMAT_JPEG) {
res = httpd_resp_send(req, (const char *)fb->buf, fb->len);
jpg_chunking_t jchunk = {req, 0};
res = frame2jpg_cb(fb, 80, jpg_encode_stream, &jchunk) ? ESP_OK : ESP_FAIL;
httpd_resp_send_chunk(req, NULL, 0);
esp_camera_fb_return(fb);
return res;
My (not completed) attempt so far is:
// Read jpg from FS, display in web server
static esp_err_t FS_handler(httpd_req_t *req) {
Serial.println("FS image requested");
String fullPath = "/image.jpg"; // test file
if (!file) {
return ESP_FAIL;
unsigned char buf[1024]; // (re-used code from ftp upload)
// How to do this ? (original code below)
//jpg_chunking_t jchunk = {req, 0};
//res = frame2jpg_cb(fb, 80, jpg_encode_stream, &jchunk) ? ESP_OK : ESP_FAIL;
//httpd_resp_send_chunk(req, NULL, 0);
file.close();
return res;
How can I connect buf with the http stream ?
Any advice much appreciated.
Thanks.
