i want to read the led from the powerbooster 1000c, the problem is, that two of them are controlled via an negative:
I've connectet the Contact bevor the resistor with A0 from my arduino an want to read the analoge signal to identify which is the value to read.
But the Problem is, that the values fluctuate verry heavy from 0 to 1023. With connectet charger and without i see tendencies but thats not an accurat value
Did anybody see my Failure?
P.S. from the red and black wires are only two connected: Battery and Ground and these are to an JST with an fuse befor
P.P.S. The Image shows only my old Test-Devices for real use i have an smaller real arduino nano (Just in Case because this is not an "real Arduino")
couka:
รre the arduinos and the 1000Cs GNDs connected?
Thanks for this, this stabilize the values, but now they are allways around 300 and only when im connecting or disconnecting the power (so that the led normally would be going on) the values drops...
Did i need an resistor to the ground from the led?
I guess you are measuring on the wrong side of the led, but I can't say for sure.
Your diagram doesn't make much sense to me.
What's VBus, where is the Arduino?
VBus is the Power of the 1000c-Powerbooster... so this is allways on.
And the other Side of the LED goes to the controller which is low when i Charge the Battery on it else it is (i think as far as i'm understanding this:
The orange and green LEDs that already exist on the PowerBoost have separate control pins, and light when the control pins go low. The current-limiting resistor is between the LED and the control pin, so to read the signals with a microcontroller's digital pin, you'll want to tap the low end of the resistor, not the cathode of the LED.
) high.
But Because it doesent work with digital read i try to read the analog value but ive doesnt get it to work
