Hi to all!! I am Giovanni from Milan, I am working on a IMU from sparkfun. I am going crazy to get the value from this gyro. The otput is angular velocity and i am triyng to explain integrals to arduino. Very complex.
The code seems work but not precisley, it loose some degrees every 90 degrees.
int sensorPin = 2; // select the input pin for the potentiometer
int ledPin = 13; // select the pin for the LED
float angularVelocity = 0; // variable to store the value coming from the sensor
float previousAngularVelocity = 0;
double orientation = 9000;
double previousOrientation = 9000;
long previousTime = 0;
unsigned long time;
// declare the ledPin as an OUTPUT:
pinMode(ledPin, OUTPUT);
pinMode(sensorPin, INPUT);
//orientation = previousOrientation;
for ( int i = 0; i < 11 ; i++) {
long treshold = 320.999;
angularVelocity = (analogRead(sensorPin) - treshold) + angularVelocity;
if (i == 10) {
angularVelocity = (angularVelocity / 10) * 0.75;
if (angularVelocity - previousAngularVelocity > - 1 && angularVelocity - previousAngularVelocity < 1) {
angularVelocity = previousAngularVelocity;
time = millis() - previousTime;
previousTime = millis();
orientation = orientation + (angularVelocity * time);
if (orientation - previousOrientation > - 1 && orientation - previousOrientation < 1 ) {
Serial.println(orientation / 100);
with this piece:
I am triyng to smooth the value and correct the oscillation. Another problem is that i have to regulate the treshold value if energy source changes. I think i have to write a auto-calibration for().
Some one have some advise to me?
This is my first time with gyros.
