Read micrometer
Hello
I need to connect micrometer 2 pcs with Arduino nano. , Now i found the code for connect micrometer 1 pcs.
from this link http://www.instructables.com/id/Interfacing-a-Digital-Micrometer-to-a-Microcontrol/but i need to micrometer 2 pcs.
Can you help me,please
Micrometer 1
int req = 5; //mic REQ line goes to pin 5 through q1 (arduino high pulls request line low)
int dat = 2; //mic Data line goes to pin 2
int clk = 3; //mic Clock line goes to pin 3
int i = 0; int j = 0; int k = 0;
float Value;
byte mydata[14];
long num;
int gearFamily = 7;
// Mode button
const int  buttonPin = 4;    // the pin 4 that the pushbutton is attached to
int buttonPushCounter = 7;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
  pinMode(req, OUTPUT);
  pinMode(clk, INPUT);
  pinMode(dat, INPUT);
  digitalWrite(clk, HIGH); // enable internal pull ups
  digitalWrite(dat, HIGH); // enable internal pull ups
  digitalWrite(req,LOW); // set request at LOW
  pinMode(buttonPin, INPUT);
// read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
    // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    if (buttonState == LOW) {
      buttonPushCounter++;
  //for next time through the loop
  lastButtonState = buttonState;
    if (buttonPushCounter == 8) {
    buttonPushCounter = 1;
  gearFamily = buttonPushCounter;
  digitalWrite(req, HIGH); // generate set request
    for( i = 0; i < 13; i++ ) {
      k = 0;
      for (j = 0; j < 4; j++) {
      while( digitalRead(clk) == LOW) { } // hold until clock is high
      while( digitalRead(clk) == HIGH) { } // hold until clock is low
      bitWrite(k, j, (digitalRead(dat) & 0x1)); // read data bits, and reverse order )
      mydata[i] = k;
// assemble measurement from bytes
char buf[7];
for(int lp=0;lp<6;lp++)
buf[lp]=mydata[lp+5]+'0';
buf[6]=0;
num=atol(buf); //assembled measurement, no decimal place added
Value=num*0.001;
Serial.println(Value, 3);
Micrometer 2 ** this my code isn't work.
//*** Setup micrometer 1 *************
int req = 5; //mic1 REQ line goes to pin 5
int dat = 2; //mic1 Data line goes to pin 2
int clk = 3; //mic1 Clock line goes to pin 3
float Value;
byte mydata[14];
long num;
int gearFamily = 7;
const int  buttonPin = 4;    // the pin that the pushbutton is attached to
//*** Setup micrometer 2 *************
int req2 = 9; //mic2 REQ line goes to pin 9 through q1 (arduino high pulls request line low)
int dat2 = 6; //mic2 Data line goes to pin 6
int clk2 = 7; //mic2 Clock line goes to pin 7
int i2 = 0; int j2 = 0; int k2 = 0;
float Value2;
byte mydata2[14];
long num2;
int gearFamily2 = 7;
const int  buttonPin2 = 8;    // the pin that the pushbutton is attached to
int buttonPushCounter2 = 7;   // counter for the number of button presses
int buttonState2 = 0;         // current state of the button
int lastButtonState2 = 0;     // previous state of the button
  pinMode(req2, OUTPUT);
  pinMode(clk2, INPUT);
  pinMode(dat2, INPUT);
  digitalWrite(clk2, HIGH); // enable internal pull ups
  digitalWrite(dat2, HIGH); // enable internal pull ups
  digitalWrite(req2,LOW); // set request at LOW
  pinMode(buttonPin2, INPUT);
  buttonState2 = digitalRead(buttonPin2);
  if (buttonState != lastButtonState||buttonState2 != lastButtonState2)
    if (buttonState == LOW)//Micro1
   if (buttonState2 == LOW)//Micro2
      buttonPushCounter2++;
  lastButtonState2 = buttonState2;
    if (buttonPushCounter2 == 8)
    buttonPushCounter2 = 1;
  gearFamily2 = buttonPushCounter2;
  digitalWrite(req2, HIGH); // generate set request
      k = 0;
      mydata[i] = k;
    for( i2 = 0; i2 < 13; i2++ ) {
      k2 = 0;
      for (j2 = 0; j2 < 4; j2++) {
      while( digitalRead(clk2) == LOW) { } // hold until clock is high
      while( digitalRead(clk2) == HIGH) { } // hold until clock is low
              bitWrite(k2, j2, (digitalRead(dat2) & 0x1)); // read data bits, and reverse order )
      mydata2[i2] = k2;
 char buf[7];
 char buf2[7];
 buf[6]=0;
 for(int lp2=0;lp2<6;lp2++)
 buf2[lp2]=mydata2[lp2+5]+'0';
 buf2[6]=0;
 num2=atol(buf2); //assembled measurement, no decimal place added
 Value=num*0.001;
 Value2=num2*0.001;
Serial.println(Value, 2);
Serial.println(Value2, 2);
You're requesting data from both devices, then expecting the second one to hold-off sending its data whilst you read data from the first.
I would suggest that that is an unrealistic expectation.
Please use the auto-format tool before posting code - it makes it easier to read.
Edit: I can't see where you stop requesting data.
AWOL:
Thanks you for your advice.
I tried as your advice, when it read first device, stop second device and when it read second device, stop first device , Now it's work
  //***  Micrometer 1*********
  digitalWrite(req2, LOW); //  stop request
    k = 0;
    mydata[i] = k;
  char buf[7];
  for(int lp=0;lp<6;lp++){
  buf[6]=0;
  Value=num*0.001;
  //***  Micrometer 2*********
  digitalWrite(req, LOW); // stop request
    k2 = 0;
    mydata2[i2] = k2;
  char buf2[7];
  buf2[6]=0;
  Value2=num2*0.001;
