Read more then 1 character from PC/serial?
Hello,
I have gotten my Arduino to detect and understand single characters from my PC serial but it won't take more then just 1 character..
If I enter the character BC and hit send from the serial monitor no such luck but if I enter A or C it works fine...
the code
int ledPin = 9; // LED connected to digital pin 9 void setup() { // initialize the serial communication: Serial.begin(115200); }
void loop() { char srlcmd; if (Serial.available()) { srlcmd = Serial.read();
if (srlcmd == 'A' ) { analogWrite(ledPin, 1); } else if (srlcmd == 'BC' ) { analogWrite(ledPin, 25); } else if (srlcmd == '0' ) { analogWrite(ledPin, 0); } } delay(30); }
end Code
Thanks for any help! Shane
You might try searching a phrase like "arduino serial read string".
Reading more than 1 character comes up very (very, very very) often.
One simple way to capture a string:
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
String readString;
        Serial.println("serial test 0021"); // so I can keep track of what is loaded
        while (Serial.available()) {
        delay(10);
      if (Serial.available() >0) {
        char c = Serial.read();
        readString += c;}
      if (readString.length() >0) {
      Serial.println(readString);
      readString="";
ok i can now get it to read in the string but no luck in comparing them... I have tried on my own a bit with such code as:
  • If (strcmp(readString, "hello") == 0)
But i get error: "error: cannot convert 'String' to 'const char*' for argument '1' to 'int strcmp(const char*, const char*)'"
so how do compare the string coming from the serial port to a predefined string in code?
Thanks for the help! Shane
You might look at some of the operations below to see if they might be of use.
http://www.arduino.cc/en/Tutorial/TextString
