I have a problem that should be really straight forward.
I'm building a line following robot. In front of the robot I have four LDR-sensors connected to a LM324 comparator chip. I would like to read the input from the comparator as a Nibble. I would then like to read them as binary numbers so I can make a if - then statement like this one.
If sensorreading = 0100 then
Do.....
elseif sensorreading = 1100 then
do....
See the picture?
I can't seem to find out how to do the programming of this.
If someone could help me with this it will be very appreciated.
Out of curiosity I would like to know hot to send out a Nibble as well.
Like if I want to control a BCD to 7-segment driver....
I can figure out the wiring myself. I want the arduino to be wired after the code not vice versa. Said in a different way: I would like the programming to be as simple and logical as possible, and make the wiring to fit the code.
Your question is a little bit hidden; there is no such thing as a "nibble"... Presumable you want to shift four input bits into a byte. Your second question is most likely how to shift 4 bits from a byte out on 4 different lines?
Depending on your programming experience, there are the bitWrite, bitRead etc functions, or there are bit OR operations with shifts.
Arduino also has handy binary constants defines, if you're not comfortable with hex.
Don't listen to him. He'll tell you the tooth fairy is a myth too.
If you're willing to make the HW follow the SW, then you can do:
nibble = PINB & 0xF;
Where your sensors are connected to digital pins 8 through 11.
This is "pure AVR programming" and not Arduino libraries any more, but I think it's a bit silly to go the lengths some people are suggesting unless there is a particularly good reason (like, say, needing to mix bits from different ports, or be portable to Mega, or...) It's not like the mishmash using digitalRead() is actually any easier to understand by the time you're done, and it's WAY slower and bigger.
Because I would like to make a simple if - then statement that decides how the robot should move depending on the sensor input.
I think it's easier to understand the code if I know that 0001 means that the line is at the rightmost sensor and if it's 0010 the line is under the third sensor and so on....
Could I use an integer variable instead of a Byte?
I agree with Richard about using the "B" notation: it's a violation of standard C/C++, and confusing.
Better practice is something like this (assumes you have sensors connected to D4 through D7):
#define HARD_LEFT 0x80
#define SLIGHT_LEFT 0x40
#define SLIGHT_RIGHT 0x20
#define HARD_RIGHT 0x10
#define SENSOR_MASK 0xf0
sensors = PIND & SENSOR_MASK;
switch (sensors)
case HARD_LEFT:
// Do left stuff
case SLIGHT_LEFT:
// Do left stuff
case SLIGHT_RIGHT:
// Do right stuff
case HARD_RIGHT:
// Do right stuff
default:
// Do "no sensor on" stuff
That makes your code easier to read, helps avoid hard-to-spot typos (like typing "3" instead of "2"), and opens up other possibilities. E.g., if the field of view of your sensors overlaps, you can do something like
#define CENTERED 0x60
to define a case where two sensors are on at once.
It's nice to see how you guys solves these kind of things.
I really like the coding examples.
Yet, I have a hard time understanding why Hex should be easier to understand. I get confused by Hex-numbers. When I look at hex I have to convert it in my head. First do dec and then to binary. Otherwise I can't really imagine where the line is :-[
When I look at something like 1000, then I know that the line is all to the left. I can do that really quickly.
One line of the code in the example above seems a bit strange to me:
Wouldn't the Arduino read digital pins 0 to 7 If I use a PIND command and store them in the byte "sensors"?
Can't I use digital pin 1,2 and 3 as outputs then?
What exactly happens here: PIND & SENSOR_MASK?
What will the Sensor byte look like in Binary afterwards if I read a 0x80 from the sensor and add the SENSOR_MASK?
The B notation is not a violation, otherwise the compiler would reject it.
It may not be in the spirit of C, but may be useful for some, with appropriate caveats.
No the whole point about hex is that it is easy to convert directly into binary in your head. Practice, write out a list of hex numbers from 0 to f and along side write the binary. No need for decimal.
Yes and that is hex 0x8 - I can do that in my head
This is anding together two numbers, Anding is a way of removing selected bits from a bit pattern (number) - a zero in a pit position of the mask wipes out the effect of a logic one in the number PIND. For a good discussion see:- http://www.arduino.cc/en/Reference/PortManipulation
