Read NMEA2000 with MCP2515 CAN Controller Module
Hello,
I am new to this forum :grinning:. I'm working on a company that just purchased an Airmar DST800 depth Multi sensor which works at 12V and uses NMEA2000 protocol. Its brochure is accessible here: https://www.airmar.com/uploads/brochures/DST800.pdf.
We are trying to read the corresponding data with a MCP2515 CAN Controller Module which is based on MCP2515 CAN Controller IC with a TJA1050 CAN Transceiver IC and uses a 8MHZ crystal. We also use an Arduino Mega.
We have successfully run some tests by sending & receiving data using two MCP2515 CAN Controller Modules and the NMEA2000 library GitHub - ttlappalainen/NMEA2000: NMEA2000 library for Arduino.
8b435133c3e35901707b993024bfaff8a2864221_2_690x281
Unfortunately, we didn't manage to collect the corresponding data from our depth sensor and we can't understand what is going wrong. We are also sure that the power supply is 12V, the wiring is correct and the sensor sends data (we checked it with an oscillator).
For the record, we use the example 'DisplayData2' from the above library in order to handle NMEA2000 protocol:
// Demo: NMEA2000 library.
// This demo reads messages from NMEA 2000 bus and
// sends them translated to clear text to Serial.
// Note! If you use this on Arduino Mega, I prefer to also connect interrupt line
// for MCP2515 and define N2k_CAN_INT_PIN to related line.
#include <Arduino.h>
#define N2k_SPI_CS_PIN 53    // Pin for SPI select for mcp_can
#define N2k_CAN_INT_PIN 21   // Interrupt pin for mcp_can
#define USE_MCP_CAN_CLOCK_SET 8  // Uncomment this, if your mcp_can shield has 8MHz chrystal
//#define ESP32_CAN_TX_PIN GPIO_NUM_16 // Uncomment this and set right CAN TX pin definition, if you use ESP32 and do not have TX on default IO 16
//#define ESP32_CAN_RX_PIN GPIO_NUM_17 // Uncomment this and set right CAN RX pin definition, if you use ESP32 and do not have RX on default IO 4
//#define NMEA2000_ARDUINO_DUE_CAN_BUS tNMEA2000_due::CANDevice1    // Uncomment this, if you want to use CAN bus 1 instead of 0 for Arduino DUE
#include <NMEA2000_CAN.h>
#include <N2kMessages.h>
#include <N2kMessagesEnumToStr.h>
typedef struct {
  unsigned long PGN;
  void (*Handler)(const tN2kMsg &N2kMsg);
} tNMEA2000Handler;
void SystemTime(const tN2kMsg &N2kMsg);
void Rudder(const tN2kMsg &N2kMsg);
void EngineRapid(const tN2kMsg &N2kMsg);
void EngineDynamicParameters(const tN2kMsg &N2kMsg);
void TransmissionParameters(const tN2kMsg &N2kMsg);
void TripFuelConsumption(const tN2kMsg &N2kMsg);
void Speed(const tN2kMsg &N2kMsg);
void WaterDepth(const tN2kMsg &N2kMsg);
void BinaryStatus(const tN2kMsg &N2kMsg);
void FluidLevel(const tN2kMsg &N2kMsg);
void OutsideEnvironmental(const tN2kMsg &N2kMsg);
void Temperature(const tN2kMsg &N2kMsg);
void TemperatureExt(const tN2kMsg &N2kMsg);
void DCStatus(const tN2kMsg &N2kMsg);
void BatteryConfigurationStatus(const tN2kMsg &N2kMsg);
void COGSOG(const tN2kMsg &N2kMsg);
void GNSS(const tN2kMsg &N2kMsg);
void LocalOffset(const tN2kMsg &N2kMsg);
void Attitude(const tN2kMsg &N2kMsg);
void Heading(const tN2kMsg &N2kMsg);
void Humidity(const tN2kMsg &N2kMsg);
void Pressure(const tN2kMsg &N2kMsg);
void UserDatumSettings(const tN2kMsg &N2kMsg);
void GNSSSatsInView(const tN2kMsg &N2kMsg);
tNMEA2000Handler NMEA2000Handlers[]={
  {126992L,&SystemTime},
  {127245L,&Rudder },
  {127250L,&Heading},
  {127257L,&Attitude},
  {127488L,&EngineRapid},
  {127489L,&EngineDynamicParameters},
  {127493L,&TransmissionParameters},
  {127497L,&TripFuelConsumption},
  {127501L,&BinaryStatus},
  {127505L,&FluidLevel},
  {127506L,&DCStatus},
  {127513L,&BatteryConfigurationStatus},
  {128259L,&Speed},
  {128267L,&WaterDepth},
  {129026L,&COGSOG},
  {129029L,&GNSS},
  {129033L,&LocalOffset},
  {129045L,&UserDatumSettings},
  {129540L,&GNSSSatsInView},
  {130310L,&OutsideEnvironmental},
  {130312L,&Temperature},
  {130313L,&Humidity},
  {130314L,&Pressure},
  {130316L,&TemperatureExt},
  {0,0}
Stream *OutputStream;
void HandleNMEA2000Msg(const tN2kMsg &N2kMsg);
  Serial.begin(115200); delay(500);
  OutputStream=&Serial;
//   while (!Serial)
//  NMEA2000.SetN2kCANReceiveFrameBufSize(50);
  // Do not forward bus messages at all
  NMEA2000.SetForwardType(tNMEA2000::fwdt_Text);
  NMEA2000.SetForwardStream(OutputStream);
  // Set false below, if you do not want to see messages parsed to HEX withing library
  NMEA2000.EnableForward(false);
  NMEA2000.SetMsgHandler(HandleNMEA2000Msg);
//  NMEA2000.SetN2kCANMsgBufSize(2);
  NMEA2000.Open();
  OutputStream->print("Running...");
template<typename T> void PrintLabelValWithConversionCheckUnDef(const char* label, T val, double (*ConvFunc)(double val)=0, bool AddLf=false, int8_t Desim=-1 ) {
  OutputStream->print(label);
  if (!N2kIsNA(val)) {
    if ( Desim<0 ) {
      if (ConvFunc) { OutputStream->print(ConvFunc(val)); } else { OutputStream->print(val); }
      if (ConvFunc) { OutputStream->print(ConvFunc(val),Desim); } else { OutputStream->print(val,Desim); }
  } else OutputStream->print("not available");
  if (AddLf) OutputStream->println();
void SystemTime(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    uint16_t SystemDate;
    double SystemTime;
    tN2kTimeSource TimeSource;
    if (ParseN2kSystemTime(N2kMsg,SID,SystemDate,SystemTime,TimeSource) ) {
                      OutputStream->println("System time:");
      PrintLabelValWithConversionCheckUnDef("  SID: ",SID,0,true);
      PrintLabelValWithConversionCheckUnDef("  days since 1.1.1970: ",SystemDate,0,true);
      PrintLabelValWithConversionCheckUnDef("  seconds since midnight: ",SystemTime,0,true);
                        OutputStream->print("  time source: "); PrintN2kEnumType(TimeSource,OutputStream);
      OutputStream->print("Failed to parse PGN: "); OutputStream->println(N2kMsg.PGN);
void Rudder(const tN2kMsg &N2kMsg) {
    unsigned char Instance;
    tN2kRudderDirectionOrder RudderDirectionOrder;
    double RudderPosition;
    double AngleOrder;
    if (ParseN2kRudder(N2kMsg,RudderPosition,Instance,RudderDirectionOrder,AngleOrder) ) {
      PrintLabelValWithConversionCheckUnDef("Rudder: ",Instance,0,true);
      PrintLabelValWithConversionCheckUnDef("  position (deg): ",RudderPosition,&RadToDeg,true);
                        OutputStream->print("  direction order: "); PrintN2kEnumType(RudderDirectionOrder,OutputStream);
      PrintLabelValWithConversionCheckUnDef("  angle order (deg): ",AngleOrder,&RadToDeg,true);
void EngineRapid(const tN2kMsg &N2kMsg) {
    unsigned char EngineInstance;
    double EngineSpeed;
    double EngineBoostPressure;
    int8_t EngineTiltTrim;
    if (ParseN2kEngineParamRapid(N2kMsg,EngineInstance,EngineSpeed,EngineBoostPressure,EngineTiltTrim) ) {
      PrintLabelValWithConversionCheckUnDef("Engine rapid params: ",EngineInstance,0,true);
      PrintLabelValWithConversionCheckUnDef("  RPM: ",EngineSpeed,0,true);
      PrintLabelValWithConversionCheckUnDef("  boost pressure (Pa): ",EngineBoostPressure,0,true);
      PrintLabelValWithConversionCheckUnDef("  tilt trim: ",EngineTiltTrim,0,true);
void EngineDynamicParameters(const tN2kMsg &N2kMsg) {
    double EngineOilPress;
    double EngineOilTemp;
    double EngineCoolantTemp;
    double AltenatorVoltage;
    double FuelRate;
    double EngineHours;
    double EngineCoolantPress;
    double EngineFuelPress;
    int8_t EngineLoad;
    int8_t EngineTorque;
    tN2kEngineDiscreteStatus1 Status1;
    tN2kEngineDiscreteStatus2 Status2;
    if (ParseN2kEngineDynamicParam(N2kMsg,EngineInstance,EngineOilPress,EngineOilTemp,EngineCoolantTemp,
                                 AltenatorVoltage,FuelRate,EngineHours,
                                 EngineCoolantPress,EngineFuelPress,
                                 EngineLoad,EngineTorque,Status1,Status2) ) {
      PrintLabelValWithConversionCheckUnDef("Engine dynamic params: ",EngineInstance,0,true);
      PrintLabelValWithConversionCheckUnDef("  oil pressure (Pa): ",EngineOilPress,0,true);
      PrintLabelValWithConversionCheckUnDef("  oil temp (C): ",EngineOilTemp,&KelvinToC,true);
      PrintLabelValWithConversionCheckUnDef("  coolant temp (C): ",EngineCoolantTemp,&KelvinToC,true);
      PrintLabelValWithConversionCheckUnDef("  altenator voltage (V): ",AltenatorVoltage,0,true);
      PrintLabelValWithConversionCheckUnDef("  fuel rate (l/h): ",FuelRate,0,true);
      PrintLabelValWithConversionCheckUnDef("  engine hours (h): ",EngineHours,&SecondsToh,true);
      PrintLabelValWithConversionCheckUnDef("  coolant pressure (Pa): ",EngineCoolantPress,0,true);
      PrintLabelValWithConversionCheckUnDef("  fuel pressure (Pa): ",EngineFuelPress,0,true);
      PrintLabelValWithConversionCheckUnDef("  engine load (%): ",EngineLoad,0,true);
      PrintLabelValWithConversionCheckUnDef("  engine torque (%): ",EngineTorque,0,true);
void TransmissionParameters(const tN2kMsg &N2kMsg) {
    tN2kTransmissionGear TransmissionGear;
    double OilPressure;
    double OilTemperature;
    unsigned char DiscreteStatus1;
    if (ParseN2kTransmissionParameters(N2kMsg,EngineInstance, TransmissionGear, OilPressure, OilTemperature, DiscreteStatus1) ) {
      PrintLabelValWithConversionCheckUnDef("Transmission params: ",EngineInstance,0,true);
                        OutputStream->print("  gear: "); PrintN2kEnumType(TransmissionGear,OutputStream);
      PrintLabelValWithConversionCheckUnDef("  oil pressure (Pa): ",OilPressure,0,true);
      PrintLabelValWithConversionCheckUnDef("  oil temperature (C): ",OilTemperature,&KelvinToC,true);
      PrintLabelValWithConversionCheckUnDef("  discrete status: ",DiscreteStatus1,0,true);
void TripFuelConsumption(const tN2kMsg &N2kMsg) {
    double TripFuelUsed;
    double FuelRateAverage;
    double FuelRateEconomy;
    double InstantaneousFuelEconomy;
    if (ParseN2kEngineTripParameters(N2kMsg,EngineInstance, TripFuelUsed, FuelRateAverage, FuelRateEconomy, InstantaneousFuelEconomy) ) {
      PrintLabelValWithConversionCheckUnDef("Trip fuel consumption: ",EngineInstance,0,true);
      PrintLabelValWithConversionCheckUnDef("  fuel used (l): ",TripFuelUsed,0,true);
      PrintLabelValWithConversionCheckUnDef("  average fuel rate (l/h): ",FuelRateAverage,0,true);
      PrintLabelValWithConversionCheckUnDef("  economy fuel rate (l/h): ",FuelRateEconomy,0,true);
      PrintLabelValWithConversionCheckUnDef("  instantaneous fuel economy (l/h): ",InstantaneousFuelEconomy,0,true);
void Heading(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    tN2kHeadingReference HeadingReference;
    double Heading;
    double Deviation;
    double Variation;
    if (ParseN2kHeading(N2kMsg,SID,Heading,Deviation,Variation,HeadingReference) ) {
                      OutputStream->println("Heading:");
                        OutputStream->print("  reference: "); PrintN2kEnumType(HeadingReference,OutputStream);
      PrintLabelValWithConversionCheckUnDef("  Heading (deg): ",Heading,&RadToDeg,true);
      PrintLabelValWithConversionCheckUnDef("  Deviation (deg): ",Deviation,&RadToDeg,true);
      PrintLabelValWithConversionCheckUnDef("  Variation (deg): ",Variation,&RadToDeg,true);
void COGSOG(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    double COG;
    double SOG;
    if (ParseN2kCOGSOGRapid(N2kMsg,SID,HeadingReference,COG,SOG) ) {
                      OutputStream->println("COG/SOG:");
      PrintLabelValWithConversionCheckUnDef("  COG (deg): ",COG,&RadToDeg,true);
      PrintLabelValWithConversionCheckUnDef("  SOG (m/s): ",SOG,0,true);
void GNSS(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    uint16_t DaysSince1970;
    double SecondsSinceMidnight;
    double Latitude;
    double Longitude;
    double Altitude;
    tN2kGNSStype GNSStype;
    tN2kGNSSmethod GNSSmethod;
    unsigned char nSatellites;
    double HDOP;
    double PDOP;
    double GeoidalSeparation;
    unsigned char nReferenceStations;
    tN2kGNSStype ReferenceStationType;
    uint16_t ReferenceSationID;
    double AgeOfCorrection;
    if (ParseN2kGNSS(N2kMsg,SID,DaysSince1970,SecondsSinceMidnight,
                  Latitude,Longitude,Altitude,
                  GNSStype,GNSSmethod,
                  nSatellites,HDOP,PDOP,GeoidalSeparation,
                  nReferenceStations,ReferenceStationType,ReferenceSationID,
                  AgeOfCorrection) ) {
                      OutputStream->println("GNSS info:");
      PrintLabelValWithConversionCheckUnDef("  days since 1.1.1970: ",DaysSince1970,0,true);
      PrintLabelValWithConversionCheckUnDef("  seconds since midnight: ",SecondsSinceMidnight,0,true);
      PrintLabelValWithConversionCheckUnDef("  latitude: ",Latitude,0,true,9);
      PrintLabelValWithConversionCheckUnDef("  longitude: ",Longitude,0,true,9);
      PrintLabelValWithConversionCheckUnDef("  altitude: (m): ",Altitude,0,true);
                        OutputStream->print("  GNSS type: "); PrintN2kEnumType(GNSStype,OutputStream);
                        OutputStream->print("  GNSS method: "); PrintN2kEnumType(GNSSmethod,OutputStream);
      PrintLabelValWithConversionCheckUnDef("  satellite count: ",nSatellites,0,true);
      PrintLabelValWithConversionCheckUnDef("  HDOP: ",HDOP,0,true);
      PrintLabelValWithConversionCheckUnDef("  PDOP: ",PDOP,0,true);
      PrintLabelValWithConversionCheckUnDef("  geoidal separation: ",GeoidalSeparation,0,true);
      PrintLabelValWithConversionCheckUnDef("  reference stations: ",nReferenceStations,0,true);
void UserDatumSettings(const tN2kMsg &N2kMsg) {
  if (N2kMsg.PGN!=129045L) return;
  int Index=0;
  double val;
  OutputStream->println("User Datum Settings: ");
  val=N2kMsg.Get4ByteDouble(1e-2,Index);
  PrintLabelValWithConversionCheckUnDef("  delta x (m): ",val,0,true);
  PrintLabelValWithConversionCheckUnDef("  delta y (m): ",val,0,true);
  PrintLabelValWithConversionCheckUnDef("  delta z (m): ",val,0,true);
  val=N2kMsg.GetFloat(Index);
  PrintLabelValWithConversionCheckUnDef("  rotation in x (deg): ",val,&RadToDeg,true,5);
  PrintLabelValWithConversionCheckUnDef("  rotation in y (deg): ",val,&RadToDeg,true,5);
  PrintLabelValWithConversionCheckUnDef("  rotation in z (deg): ",val,&RadToDeg,true,5);
  PrintLabelValWithConversionCheckUnDef("  scale: ",val,0,true,3);
void GNSSSatsInView(const tN2kMsg &N2kMsg) {
  unsigned char SID;
  tN2kRangeResidualMode Mode;
  uint8_t NumberOfSVs;
  tSatelliteInfo SatelliteInfo;
  if (ParseN2kPGNSatellitesInView(N2kMsg,SID,Mode,NumberOfSVs) ) {
    OutputStream->println("Satellites in view: ");
                      OutputStream->print("  mode: "); OutputStream->println(Mode);
                      OutputStream->print("  number of satellites: ");  OutputStream->println(NumberOfSVs);
    for ( uint8_t i=0; i<NumberOfSVs && ParseN2kPGNSatellitesInView(N2kMsg,i,SatelliteInfo); i++) {
                        OutputStream->print("  Satellite PRN: ");  OutputStream->println(SatelliteInfo.PRN);
      PrintLabelValWithConversionCheckUnDef("    elevation: ",SatelliteInfo.Elevation,&RadToDeg,true,1);
      PrintLabelValWithConversionCheckUnDef("    azimuth:   ",SatelliteInfo.Azimuth,&RadToDeg,true,1);
      PrintLabelValWithConversionCheckUnDef("    SNR:       ",SatelliteInfo.SNR,0,true,1);
      PrintLabelValWithConversionCheckUnDef("    residuals: ",SatelliteInfo.RangeResiduals,0,true,1);
                        OutputStream->print("    status: "); OutputStream->println(SatelliteInfo.UsageStatus);
void LocalOffset(const tN2kMsg &N2kMsg) {
    double SystemTime;
    int16_t Offset;
    if (ParseN2kLocalOffset(N2kMsg,SystemDate,SystemTime,Offset) ) {
                      OutputStream->println("Date,time and local offset: ");
      PrintLabelValWithConversionCheckUnDef("  local offset (min): ",Offset,0,true);
void OutsideEnvironmental(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    double WaterTemperature;
    double OutsideAmbientAirTemperature;
    double AtmosphericPressure;
    if (ParseN2kOutsideEnvironmentalParameters(N2kMsg,SID,WaterTemperature,OutsideAmbientAirTemperature,AtmosphericPressure) ) {
      PrintLabelValWithConversionCheckUnDef("Water temp: ",WaterTemperature,&KelvinToC);
      PrintLabelValWithConversionCheckUnDef(", outside ambient temp: ",OutsideAmbientAirTemperature,&KelvinToC);
      PrintLabelValWithConversionCheckUnDef(", pressure: ",AtmosphericPressure,0,true);
void Temperature(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    unsigned char TempInstance;
    tN2kTempSource TempSource;
    double ActualTemperature;
    double SetTemperature;
    if (ParseN2kTemperature(N2kMsg,SID,TempInstance,TempSource,ActualTemperature,SetTemperature) ) {
                        OutputStream->print("Temperature source: "); PrintN2kEnumType(TempSource,OutputStream,false);
      PrintLabelValWithConversionCheckUnDef(", actual temperature: ",ActualTemperature,&KelvinToC);
      PrintLabelValWithConversionCheckUnDef(", set temperature: ",SetTemperature,&KelvinToC,true);
void Humidity(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    tN2kHumiditySource HumiditySource;
    double ActualHumidity,SetHumidity;
    if ( ParseN2kHumidity(N2kMsg,SID,Instance,HumiditySource,ActualHumidity,SetHumidity) ) {
                        OutputStream->print("Humidity source: "); PrintN2kEnumType(HumiditySource,OutputStream,false);
      PrintLabelValWithConversionCheckUnDef(", humidity: ",ActualHumidity,0,false);
      PrintLabelValWithConversionCheckUnDef(", set humidity: ",SetHumidity,0,true);
void Pressure(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    tN2kPressureSource PressureSource;
    double ActualPressure;
    if ( ParseN2kPressure(N2kMsg,SID,Instance,PressureSource,ActualPressure) ) {
                        OutputStream->print("Pressure source: "); PrintN2kEnumType(PressureSource,OutputStream,false);
      PrintLabelValWithConversionCheckUnDef(", pressure: ",ActualPressure,&PascalTomBar,true);
void TemperatureExt(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    if (ParseN2kTemperatureExt(N2kMsg,SID,TempInstance,TempSource,ActualTemperature,SetTemperature) ) {
void BatteryConfigurationStatus(const tN2kMsg &N2kMsg) {
    unsigned char BatInstance;
    tN2kBatType BatType;
    tN2kBatEqSupport SupportsEqual;
    tN2kBatNomVolt BatNominalVoltage;
    tN2kBatChem BatChemistry;
    double BatCapacity;
    int8_t BatTemperatureCoefficient;
    double PeukertExponent;
    int8_t ChargeEfficiencyFactor;
    if (ParseN2kBatConf(N2kMsg,BatInstance,BatType,SupportsEqual,BatNominalVoltage,BatChemistry,BatCapacity,BatTemperatureCoefficient,PeukertExponent,ChargeEfficiencyFactor) ) {
      PrintLabelValWithConversionCheckUnDef("Battery instance: ",BatInstance,0,true);
                        OutputStream->print("  - type: "); PrintN2kEnumType(BatType,OutputStream);
                        OutputStream->print("  - support equal.: "); PrintN2kEnumType(SupportsEqual,OutputStream);
                        OutputStream->print("  - nominal voltage: "); PrintN2kEnumType(BatNominalVoltage,OutputStream);
                        OutputStream->print("  - chemistry: "); PrintN2kEnumType(BatChemistry,OutputStream);
      PrintLabelValWithConversionCheckUnDef("  - capacity (Ah): ",BatCapacity,&CoulombToAh,true);
      PrintLabelValWithConversionCheckUnDef("  - temperature coefficient (%): ",BatTemperatureCoefficient,0,true);
      PrintLabelValWithConversionCheckUnDef("  - peukert exponent: ",PeukertExponent,0,true);
      PrintLabelValWithConversionCheckUnDef("  - charge efficiency factor (%): ",ChargeEfficiencyFactor,0,true);
void DCStatus(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    unsigned char DCInstance;
    tN2kDCType DCType;
    unsigned char StateOfCharge;
    unsigned char StateOfHealth;
    double TimeRemaining;
    double RippleVoltage;
    double Capacity;
    if (ParseN2kDCStatus(N2kMsg,SID,DCInstance,DCType,StateOfCharge,StateOfHealth,TimeRemaining,RippleVoltage,Capacity) ) {
      OutputStream->print("DC instance: ");
      OutputStream->println(DCInstance);
      OutputStream->print("  - type: "); PrintN2kEnumType(DCType,OutputStream);
      OutputStream->print("  - state of charge (%): "); OutputStream->println(StateOfCharge);
      OutputStream->print("  - state of health (%): "); OutputStream->println(StateOfHealth);
      OutputStream->print("  - time remaining (h): "); OutputStream->println(TimeRemaining/60);
      OutputStream->print("  - ripple voltage: "); OutputStream->println(RippleVoltage);
      OutputStream->print("  - capacity: "); OutputStream->println(Capacity);
void Speed(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    double SOW;
    double SOG;
    tN2kSpeedWaterReferenceType SWRT;
    if (ParseN2kBoatSpeed(N2kMsg,SID,SOW,SOG,SWRT) ) {
      OutputStream->print("Boat speed:");
      PrintLabelValWithConversionCheckUnDef(" SOW:",N2kIsNA(SOW)?SOW:msToKnots(SOW));
      PrintLabelValWithConversionCheckUnDef(", SOG:",N2kIsNA(SOG)?SOG:msToKnots(SOG));
      OutputStream->print(", ");
      PrintN2kEnumType(SWRT,OutputStream,true);
void WaterDepth(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    double DepthBelowTransducer;
    double Offset;
    if (ParseN2kWaterDepth(N2kMsg,SID,DepthBelowTransducer,Offset) ) {
      if ( N2kIsNA(Offset) || Offset == 0 ) {
        PrintLabelValWithConversionCheckUnDef("Depth below transducer",DepthBelowTransducer);
        if ( N2kIsNA(Offset) ) {
          OutputStream->println(", offset not available");
          OutputStream->println(", offset=0");
        if (Offset>0) {
          OutputStream->print("Water depth:");
          OutputStream->print("Depth below keel:");
        if ( !N2kIsNA(DepthBelowTransducer) ) {
          OutputStream->println(DepthBelowTransducer+Offset);
        } else {  OutputStream->println(" not available"); }
void printLLNumber(Stream *OutputStream, unsigned long long n, uint8_t base=10)
  unsigned char buf[16 * sizeof(long)]; // Assumes 8-bit chars.
  unsigned long long i = 0;
  if (n == 0) {
    OutputStream->print('0');
    return;
  while (n > 0) {
    buf[i++] = n % base;
    n /= base;
  for (; i > 0; i--)
    OutputStream->print((char) (buf[i - 1] < 10 ?
      '0' + buf[i - 1] :
      'A' + buf[i - 1] - 10));
void BinaryStatusFull(const tN2kMsg &N2kMsg) {
    unsigned char BankInstance;
    tN2kBinaryStatus BankStatus;
    if (ParseN2kBinaryStatus(N2kMsg,BankInstance,BankStatus) ) {
      OutputStream->print("Binary status for bank "); OutputStream->print(BankInstance); OutputStream->println(":");
      OutputStream->print("  "); //printLLNumber(OutputStream,BankStatus,16);
      for (uint8_t i=1; i<=28; i++) {
        if (i>1) OutputStream->print(",");
        PrintN2kEnumType(N2kGetStatusOnBinaryStatus(BankStatus,i),OutputStream,false);
void BinaryStatus(const tN2kMsg &N2kMsg) {
    tN2kOnOff Status1,Status2,Status3,Status4;
    if (ParseN2kBinaryStatus(N2kMsg,BankInstance,Status1,Status2,Status3,Status4) ) {
      if (BankInstance>2) { // note that this is only for testing different methods. MessageSender.ini sends 4 status for instace 2
        BinaryStatusFull(N2kMsg);
        OutputStream->print("  Status1=");PrintN2kEnumType(Status1,OutputStream,false);
        OutputStream->print(", Status2=");PrintN2kEnumType(Status2,OutputStream,false);
        OutputStream->print(", Status3=");PrintN2kEnumType(Status3,OutputStream,false);
        OutputStream->print(", Status4=");PrintN2kEnumType(Status4,OutputStream,false);
void FluidLevel(const tN2kMsg &N2kMsg) {
    tN2kFluidType FluidType;
    double Level=0;
    double Capacity=0;
    if (ParseN2kFluidLevel(N2kMsg,Instance,FluidType,Level,Capacity) ) {
      switch (FluidType) {
        case N2kft_Fuel:
          OutputStream->print("Fuel level :");
        case N2kft_Water:
          OutputStream->print("Water level :");
        case N2kft_GrayWater:
          OutputStream->print("Gray water level :");
        case N2kft_LiveWell:
          OutputStream->print("Live well level :");
        case N2kft_Oil:
          OutputStream->print("Oil level :");
        case N2kft_BlackWater:
          OutputStream->print("Black water level :");
        case N2kft_FuelGasoline:
          OutputStream->print("Gasoline level :");
        case N2kft_Error:
          OutputStream->print("Error level :");
        case N2kft_Unavailable:
          OutputStream->print("Unknown level :");
      OutputStream->print(Level); OutputStream->print("%");
      OutputStream->print(" ("); OutputStream->print(Capacity*Level/100); OutputStream->print("l)");
      OutputStream->print(" capacity :"); OutputStream->println(Capacity);
void Attitude(const tN2kMsg &N2kMsg) {
    unsigned char SID;
    double Yaw;
    double Pitch;
    double Roll;
    if (ParseN2kAttitude(N2kMsg,SID,Yaw,Pitch,Roll) ) {
                      OutputStream->println("Attitude:");
      PrintLabelValWithConversionCheckUnDef("  Yaw (deg): ",Yaw,&RadToDeg,true);
      PrintLabelValWithConversionCheckUnDef("  Pitch (deg): ",Pitch,&RadToDeg,true);
      PrintLabelValWithConversionCheckUnDef("  Roll (deg): ",Roll,&RadToDeg,true);
//NMEA 2000 message handler
void HandleNMEA2000Msg(const tN2kMsg &N2kMsg) {
  int iHandler;
  // Find handler
  OutputStream->print("In Main Handler: "); OutputStream->println(N2kMsg.PGN);
  for (iHandler=0; NMEA2000Handlers[iHandler].PGN!=0 && !(N2kMsg.PGN==NMEA2000Handlers[iHandler].PGN); iHandler++);
  if (NMEA2000Handlers[iHandler].PGN!=0) {
    NMEA2000Handlers[iHandler].Handler(N2kMsg);
  NMEA2000.ParseMessages();
