read payload only (NFC tag emulation)
hi everyone,
iam using the seedstudio v2 nfc board and i only want to select the payload of what i send trough nfc to arduino to show up on the serial monitor. (Tag emulation)
this is my code:
#include "SPI.h"
#include "PN532_SPI.h"
#include "emulatetag.h"
#include "NdefMessage.h"
PN532_SPI pn532spi(SPI, 10);
EmulateTag nfc(pn532spi);
uint8_t ndefBuf[120];
const int led = 13;
String content = "";
char character;
  Serial.println("------- Emulate Tag --------");
  pinMode(led, OUTPUT);
  nfc.init();
void loop(){
  // start emulation (blocks)
  nfc.emulate();
  if(nfc.writeOccured()){
    digitalWrite(led, HIGH);
    Serial.println("\nWrite occured !");
    uint8_t* tag_buf;
    uint16_t length;
    nfc.getContent(&tag_buf, &length);
    NdefMessage msg = NdefMessage(tag_buf, length);
    msg.print();
currently i get this is my serial monitor:
Write occured !
NDEF Message 1 record, 16 bytes
NDEF Record
TNF 0x1 Well Known
Type Length 0x1 1
Payload Length 0xC 12
Type 54 T
Payload 02 65 6E 6F 6E 6C 79 20 74 68 69 73 .only this <-- thats the only thing i want to show in the serial monitor
Record is 16 bytes
things i tried to select the payload: indexof(), msg.substring() and tried this (stackoverflow)
i hope you guys can help me out a bit, would really appreciate it :slight_smile:
Links to the libraries you are using would be good.
testmaniac:
hi everyone,
::::SNIP::::
The easiest way is to change it to a String object.
References:
This should work. If it does not, I'll be happy to help.
Change from:
 msg.print();
to:
 String msg = NdefMessage(tag_buf, length);
 indx = msg.indexOf('Payload');
 if (indx != -1) {
     payload = msg.substring(indx)
     Serial.println(payload);
It's work ??? Because me not work..
when i change
"NdefMessage msg = NdefMessage(tag_buf, length);
msg.print(); "
to
" String msg = NdefMessage(tag_buf, length);
if (indx != -1) {
there is a problem :
C:\Users\Thierry\Desktop\emulation\emulation.ino:34:21: warning: character constant too long for its type [enabled by default]
C:\Users\Thierry\Desktop\emulation\emulation.ino: In function 'void loop()':
emulation:33: error: conversion from 'NdefMessage' to non-scalar type 'String' requested
emulation:34: error: 'indx' was not declared in this scope
C:\Users\Thierry\Desktop\emulation\emulation.ino:34:30: warning: overflow in implicit constant conversion [-Woverflow]
emulation:36: error: 'payload' was not declared in this scope
emulation:37: error: expected ';' before 'Serial'
exit status 1
do u have an answer ? Can u read the only payload ?
Do not do things that do not make sense. You can NOT assign an instance of NdefMessage to a String.
YOU must look at the NdefMessage class and figure out how to print (or save) just the portion you want.
