Read RC pulse that actually works?
Hi all
I tried RCArduinoFastLib and it is so glitchy and it sends random throttle to the RC car and i tried PulseIn but it is too slow.
Is there a working glitchless RC read pulse code?
pulseIn() blocks until a pulse is received or it times out. What did you have the timeout set to ?
I dont remember...
David121:
I dont remember...
The default is 1 second but it would be a very strange RC system if that was ever triggered.
How are the RC receiver and Arduino wired together ? What is powering both and do they have a common GND ?
UKHeliBob:
an ESC BEC was powering receiver at 6V, arduino powered through VIN from receiver, yes same ground.
1ms is full reverse, 1.5 ms neutral and 2ms is full throttle
Not a good idea to power the Arduino with 6V through VIN. That could certainly explain the glitchiness.
jremington:
Are you implying i am not sending enough power to the Arduino? that could may be the problem since its shared power with a hungry servo. maybe i should try all the libraries again using a separate power source
That was a statement of fact. Sharing the power with a servo makes the situation much worse.
Use a separate regulator to provide 7V minimum to Vin or 5V to Vcc for the Arduino.
jremington:
ill use a 2s lipo to vin directly and try again. ill post back soon as i try it out
I have given up for now. I tried using separate power and only relayed the throttle through the arduino but the code was sending the most random pulses to the ESC. This was using RCArduinoFastLib.
