#include <VarSpeedServo.h>
#include "ThreeStateDoubleSwitch.h"
#define NUM_OUTPUTS 8
#define NUM_SERVOS 4
#define NUM_SWITCHES 4
// ISR variables
byte last_channel_1;
unsigned long timer_1, current_time, receiver_input;
volatile uint8_t current_output = 0;
volatile uint8_t output_ready = 0;
volatile int multi_output[NUM_OUTPUTS] = {0,}; // Array that holds effective RC reading from multiprop;
int nonISR_output[NUM_OUTPUTS] = {0,}; // Array that holds a copy multi_output values, outside ISR
uint8_t outputA_pins[NUM_OUTPUTS];
uint8_t outputB_pins[NUM_OUTPUTS];
uint8_t SPEED = 28; // servo speed for speed library, value from 0 to 255;
//Servo servos[NUM_SERVOS]; // only 4 servo, 1 per each prop, only one servo used in my experiment
VarSpeedServo servos[NUM_SERVOS];
ThreeStateDoubleSwitch switches[NUM_SWITCHES];
// Serial.begin(115200);
PCICR |= (1 << PCIE0); //Set PCIE0 to enable PCMSK0 scan.
PCMSK0 |= (1 << PCINT0); //Set PCINT0 (digital input 8) to trigger an interrupt on state change.
// Init array of output pins
// 1-4 - Props
// 5-8 - 3 Position Switches
// Primary function array, includes both switched and props
outputA_pins[0] = 6; // Prop 1
outputA_pins[1] = 0; // Prop 2
outputA_pins[2] = 0; // Prop 3
outputA_pins[3] = 0; // Prop 4
outputA_pins[4] = 7; // Switch 1
outputA_pins[5] = 0; // Switch 2
outputA_pins[6] = 0; // Switch 3
outputA_pins[7] = 0; // Switch 4
// Secondary function array, includes only switches
outputB_pins[0] = 0; // Prop 1 - not used, reserved for 2 switching function
outputB_pins[1] = 0; // Prop 2 - not used, reserved for 2 switching function
outputB_pins[2] = 0; // Prop 3 - not used, reserved for 2 switching function
outputB_pins[3] = 0; // Prop 4 - not used, reserved for 2 switching function
outputB_pins[4] = 9; // Switch 1
outputB_pins[5] = 0; // Switch 2
outputB_pins[6] = 0; // Switch 3
outputB_pins[7] = 0; // Switch 4
// assign output pins
for( uint8_t outputnum=0; outputnum<NUM_OUTPUTS; outputnum++ )
if( outputA_pins[outputnum] != 0 )
pinMode( outputA_pins[outputnum], OUTPUT );
pinMode( outputB_pins[outputnum], OUTPUT );
}//if
}//for
//set up the array of switch and servo objects, and init switch to LOW and servo to a "centered" position
if( outputnum > 3 )
//non-servo outputs
digitalWrite( outputA_pins[outputnum], LOW );
if( outputB_pins[outputnum] != 0 )
digitalWrite( outputB_pins[outputnum], LOW );
}//if
//servo outputs
multi_output[outputnum] = 1500;
servos[outputnum].attach( outputA_pins[outputnum], 1020,1980 );
servos[outputnum].write( map(multi_output[outputnum],1020,1980,5,175),SPEED );
}//if
}//else
}//for
}//setup
if (output_ready == 1) {
for (outputnum = 0; outputnum < 8; outputnum++) {
Serial.print(outputnum);
Serial.print("/");
Serial.print(multi_output[outputnum]);
Serial.print(" ");
delay(250);
//if the interrupt routine flag is set, we have a set of servos to move
if( output_ready == 1 )
noInterrupts();
// copy ISR_accessed array to working, non-ISR array in protected section
for( uint8_t outputnum=0; outputnum<8; outputnum++ ){
nonISR_output[outputnum] = multi_output[outputnum];
}//for
interrupts();
for (uint8_t outputnum = 0; outputnum < 8; outputnum++)
switch( outputnum )
case 0:
// I only use one Prop to drive a servo, position 1
servos[outputnum].write( map(nonISR_output[outputnum],1020,1980,5,175), SPEED);
//servos[outputnum].writeMicroseconds(nonISR_output[outputnum]);
//case 1:
//case 2:
//case 3:
case 4:
// I only use one switch to light two distinct led circuits, position 5
switches[outputnum-4].computeNewState(nonISR_output[outputnum]);
//check the on/off state and act
digitalWrite(outputA_pins[outputnum], switches[outputnum-4].isUpperSwitchOn() ? HIGH:LOW );
digitalWrite(outputB_pins[outputnum], switches[outputnum-4].isLowerSwitchOn() ? HIGH:LOW );
//case 5:
//case 6:
case 7:
if( (nonISR_output[outputnum] >= 1020) && (nonISR_output[outputnum] <= 1070) )
digitalWrite( outputA_pins[outputnum], HIGH );
}//if
if( (nonISR_output[outputnum] >= 1940) && (nonISR_output[outputnum] <= 1980) )
digitalWrite( outputB_pins[outputnum], HIGH );
}//if
if( (nonISR_output[outputnum] >= 1480) && (nonISR_output[outputnum] <= 1540) )
}//if
}//switch
}//for
}//if
}//loop
ISR(PCINT0_vect){
current_time = micros();
//Receiver Channel 6 to D8
if(PINB & B00000001){ //Is input 8 high?
if(last_channel_1 == 0){ //Input 8 changed from 0 to 1.
last_channel_1 = 1; //Remember current input state.
timer_1 = current_time; //Set timer_1 to current_time.
else if(last_channel_1 == 1){ //Input 8 is not high and changed from 1 to 0.
last_channel_1 = 0; //Remember current input state.
receiver_input = current_time - timer_1; //Channel 6 is current_time - timer_1.
if ((receiver_input > 850)&&(receiver_input <950)){
current_output = 0;
else {
if (current_output <8){
multi_output[current_output]= receiver_input;
current_output++;
output_ready = 1;
Posted also the code here.
In the absence of an oscilloscope, I run Nick Gammon's(Gammon Forum : Electronics : Microprocessors : Timers and counters) codes("Measuring a duty cycle using the input capture unit") which returned the following results:
signal train pulse duration and frequency:
20:54:25.614 -> Took: 931.69 uS. - Sync
20:54:26.125 -> Took: 1518.56 uS.
20:54:26.639 -> Took: 1059.00 uS.
20:54:27.117 -> Took: 1519.38 uS.
20:54:27.630 -> Took: 1058.94 uS.
20:54:28.145 -> Took: 1518.69 uS.
20:54:28.658 -> Took: 1058.94 uS.
20:54:29.169 -> Took: 1518.38 uS.
20:54:29.647 -> Took: 1058.69 uS.
21:01:12.297 -> Took: 351478 counts. Frequency: 45.52 Hz.
21:01:12.842 -> Took: 351475 counts. Frequency: 45.52 Hz.
21:01:13.350 -> Took: 351477 counts. Frequency: 45.52 Hz.
21:01:13.899 -> Took: 351470 counts. Frequency: 45.52 Hz.
21:01:14.411 -> Took: 351475 counts. Frequency: 45.52 Hz.
21:01:14.956 -> Took: 351479 counts. Frequency: 45.52 Hz.
21:01:15.469 -> Took: 351474 counts. Frequency: 45.52 Hz.
21:01:16.018 -> Took: 351485 counts. Frequency: 45.52 Hz.
21:01:16.532 -> Took: 351477 counts. Frequency: 45.52 Hz.
according the above data, servo(sub- channel) is receiving data only 5(45/9 pulses including the sync one) times per second, hence the need to slow down the servo speed in order to prevent the jerky move.
