Hi Arduino Audio developers.
I am developing a polyphonic synthesiser controller as part of a larger project. Whilst the code works there seem to be some serious performance (or data stream corruption) issues when receiving multiple notes or chords via Midi In.
Currently I have an Arduino Uno connected to a Midi IN circuit based on a 6n137 opto-isolator. I am using the standard Midi library (version 4.2). The Midi Rx from pin 6 of the 6n137 opto-isolator is connected to Digital Pin 2 of the Arduino, using a dedicated SoftwareSerial port for Midi. This is to allow use of the hardware Serial USB port for debugging using Serial.println as the SerialMonitor cannot be set at the correct speed for Midi (31250 baud). The Lcd display uses digital pins 4-7 and 8,9. The Midi IN socket is connected to a polyphonic keyboard.
The code is as follows:
#include <LiquidCrystal.h>
#include <MIDI.h>
#include <string.h>
#include <stdio.h>
#define DEBUG
#define NUM_VOICES 6
#if defined(ARDUINO_SAM_DUE) || defined(USBCON)
// Print through USB and bench with Hardware serial
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
#else
#include <SoftwareSerial.h>
SoftwareSerial midiSerial(2, 3); // midi Serial Port
MIDI_CREATE_INSTANCE(SoftwareSerial, midiSerial, MIDI);
#endif
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
typedef struct Voice
byte channel;
byte note;
byte velocity;
boolean assigned;
static struct Voice v[NUM_VOICES];
static short voiceloop = 0;
MIDI.setHandleNoteOn(handleNoteOn);
MIDI.setHandleNoteOff(handleNoteOff);
MIDI.begin(MIDI_CHANNEL_OMNI);
lcd.begin(16,2);
lcd.noCursor();
lcd.clear();
lcd.print("Synthtest");
memset(v, 0, sizeof(struct Voice) * NUM_VOICES);
for (int i = 0; i < NUM_VOICES; i++)
v[i].assigned = false;
#ifdef DEBUG
Serial.begin(115200); // This is the Debug Serial Port (using Serial.println to view data)
Serial.println("Synthesiser Debug Test");
#endif
} /* function setup */
MIDI.read();
} /* function loop */
void handleNoteOn(byte inChannel, byte inNote, byte inVelocity)
if (inVelocity > 0)
assignNoteToVoice(inChannel, inNote, inVelocity);
#ifdef DEBUG
debugMidi(9, inChannel, inNote, inVelocity);
#endif
unassignNoteFromVoice(inChannel, inNote);
#ifdef DEBUG
debugMidi(8, inChannel, inNote, inVelocity);
#endif
#ifdef DEBUG
debugVoice();
#endif
void handleNoteOff(byte inChannel, byte inNote, byte inVelocity)
#ifdef DEBUG
#endif
#ifdef DEBUG
debugVoice();
#endif
#ifdef DEBUG
void debugMidi(byte inCmd, byte inChannel, byte inNote, byte inVelocity)
// dumps midi data to Serial.println
#endif
#ifdef DEBUG
void debugVoice()
// dump voice data to Serial.println
#endif
void assignNoteToVoice(byte inChannel, byte inNote, byte inVelocity)
int index;
boolean steal = true;
for (int i=0; i < NUM_VOICES; i++)
index = (voiceloop + i) % NUM_VOICES;
if (! v[index].assigned)
steal = false;
v[index].assigned = true;
v[index].channel = inChannel;
v[index].note = inNote;
v[index].velocity = inVelocity;
if (steal)
index = (voiceloop) % NUM_VOICES;
voiceloop = (voiceloop + 1) % NUM_VOICES;
void unassignNoteFromVoice(byte inChannel, byte inNote)
if ((v[i].assigned) && (v[i].channel == inChannel) && (v[i].note == inNote))
The code works correctly for single notes played slowly. For example, playing a single middle C, the NoteOn callback captures this note (ID 60, Midi C4) and this is placed in the first voice slot. On receiving the NoteOff message the voice is unassigned from the note. Subsequent notes are placed in sucessive voices.
note ON: chn:01 nte:60 vel:84
[60] [ ] [ ] [ ] [ ] [ ]
note OFF: chn:01 nte:60 vel:00
When playing chords the underlying logic works most of the time. For example, playing a C-major triad from middle C is shown. The debug dump below shows all 3 Midi NoteOn commands being assigned to a voice, and the corresponding NoteOff calls result in the voice being de-assigned. This is correct, and the Note off messages from the callback routine correspond to a note which has already had a prior NoteOn message.
note ON: chn:01 nte:67 vel:69
[ ] [67] [ ] [ ] [ ] [ ]
note ON: chn:01 nte:64 vel:69
[ ] [67] [64] [ ] [ ] [ ]
note ON: chn:01 nte:60 vel:81
[ ] [67] [64] [60] [ ] [ ]
note OFF: chn:01 nte:64 vel:00
[ ] [67] [ ] [60] [ ] [ ]
note OFF: chn:01 nte:67 vel:00
[ ] [ ] [ ] [60] [ ] [ ]
However, in many cases the NoteOff either fails to be recognised (i.e. data not sent to the callback routine) , or I receive a NoteOff command for a Note that has not been played. In both cases, this leaves a stuck note assigned to the voice. The below example is a 5-note E-minor chord, but the Midi callback has not received the NoteOff message for one of the notes (in this case the B of the E-minor chord):
note ON: chn:01 nte:52 vel:28
[52] [ ] [ ] [ ] [ ] [ ]
note ON: chn:01 nte:55 vel:44
[52] [55] [ ] [ ] [ ] [ ]
note ON: chn:01 nte:59 vel:44
[52] [55] [59] [ ] [ ] [ ]
note ON: chn:01 nte:67 vel:84
[52] [55] [59] [67] [ ] [ ]
note ON: chn:01 nte:64 vel:55
[52] [55] [59] [67] [64] [ ]
note OFF: chn:01 nte:55 vel:00
[52] [ ] [59] [67] [64] [ ]
[52] [ ] [59] [ ] [64] [ ]
note OFF: chn:01 nte:52 vel:00
[ ] [ ] [59] [ ] [64] [ ]
[ ] [ ] [59] [ ] [ ] [ ]
Here is a dump of a C-major triad - where one Note off is missing and a noteOn has been received for note 25 (which is outside the bounds of the keyboard being used to transmit the midi data.
note ON: chn:01 nte:55 vel:67
[ ] [55] [ ] [ ] [ ] [ ]
note ON: chn:01 nte:52 vel:69
[ ] [55] [52] [ ] [ ] [ ]
note ON: chn:01 nte:48 vel:49
[ ] [55] [52] [48] [ ] [ ]
[ ] [55] [ ] [48] [ ] [ ]
[ ] [ ] [ ] [48] [ ] [ ]
note ON: chn:01 nte:25 vel:38
[ ] [ ] [ ] [48] [25] [ ]
Another incorrect outcome is that a NoteOff is received for a note that has not been played.
Possibilities:
1 - Does Midi Receive work correctly on a SoftwareSerial port (in this case using pin 2 for Midi Rx)? Do you require any extra commands to flush the Serial port stream? As mentioned, receiving Midi via Pin 0 corrupts the data as the Serial Print also uses the same port, for example Pin 0 is specified when using the “default” Midi class initialisation macro: MIDI_CREATE_DEFAULT INSTANCE, so this cannot be used.
2 - could this be a problem with the opto-isolator? I believe that the 6N137 is faster than the 6N138.
3 - is this a problem with the speed of the Arduino Uno itself, i.e. it cannot keep up with the midi In stream when chords are played. I would have thought that a Arduino Uno would be many times faster than the chips used to control polyphonic synthesisers back in the 1980s. There is no other code within the loop function other than the MIDI.Read() method.
Please note that I have removed the Lcd library and Lcd display code from the project in an effort to isolate this - this does not cure the issue.
The most puzzling issue is that the NoteOn messages appear to work correctly, it is the NoteOff data that is missing or corrupted. However this may be an illusion, as the callback would not be called if the valid Note On data had not been read from the Midi data stream.
Any help would be much appreciated.
Thanks in advance
SpaceAvenger.
