Read received bluetooth string in a while loop
Hi guys, I’m a beginner of Arduino and of coding too. I’m designing a product for a university project that requires bluetooth communication with a bridge app connected to a ProtoPie app prototype.
I’ve coded most of the code, but I really need your help…
Once a button is pressed on the app, it sends a string to my Arduino Nano 33 BLE through a bridge app that starts a while loop with a defined duration. I’d like to exit from this while loop when another string is sended by the application, but the problem is that when it enters in the loop, Arduino doesn’t read the bluetooth strings anymore until the defined time has elapsed and it exit from the while loop.
You can find the while loop in the “BREATHING MODE ACTIVATION” section, while all the bluetooth parameters are in the “BLUETOOTH” section just after the loop function.
(I had to cut some parts of the code, because of the characters limit)
#include <CapacitiveSensor.h>
#include <ArduinoBLE.h>
int LDR = A0;
int LDRread = 0;
int BUTTON = 2;
int BUTTONstate = 0;
int brBUTTON = 4;
int brBUTTONstate = 0;
///////////////BLUETOOTH////////////////
BLEService protopieService("4fafc201-1fb5-459e-8fcc-c5c9c331914b");
BLEStringCharacteristic protopieCharacteristic("beb5483e-36e1-4688-b7f5-ea07361b26a8", BLERead | BLEWrite | BLENotify, 20 );
long timePass = 0;
///////////////TURN ON LIGHT VARIABLES////////////////
int currVal = 0;
int lastVal = 0;
bool lowLight = false;
///////////////BREATHING MODE VARIABLES////////////////
bool breathingModeActivation = false;
int curbrVal = 0;
int lastbrVal = 0;
int ColorR = 0, ColorG = 0, ColorB = 0;
int interval;
#define PIN 6
#define NUMPIXELS 24
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
  pinMode(LDR, INPUT);
  pinMode(BUTTON, INPUT);
  pinMode(brBUTTON, INPUT);
  pixels.begin();
  pixels.show();
// bluetooth startup
  if (!BLE.begin()) {
    Serial.println("starting BLE failed!");
    while(1); //stop execution if BLE error
  Serial.println("Blueooth ok");
  //Initialize BLE with name and characteristics
  BLE.setLocalName("HUGY"); //Change your device name
  BLE.setAdvertisedService(protopieService);
  protopieService.addCharacteristic(protopieCharacteristic);
  BLE.addService(protopieService);
  BLE.setEventHandler(BLEConnected, blePeripheralConnectHandler);
  BLE.setEventHandler(BLEDisconnected, blePeripheralDisconnectHandler);
  protopieCharacteristic.setEventHandler(BLEWritten, protopieCharacteristicWritten);
  //Set initial value on characteristic and turn on bluetooth advetising
  protopieCharacteristic.writeValue("");
  // start advertising
  BLE.advertise();
//ccommand to send/receive between Arduino and Protopie
String BREATHINGMODE10 = "BREATHINGMODE10";
String BREATHINGMODE30 = "BREATHINGMODE30";
String OFF = "OFF";
int toggle = 0;
  LDRread = analogRead(LDR); //it is the value red from the photoresistor (LDR)
  BUTTONstate = digitalRead(BUTTON);
  brBUTTONstate = digitalRead(brBUTTON);
  //Serial.println(LDRread);
  val = TouchSensor.capacitiveSensor(30);
  delay(50); //delay of checking light intensity
  //Check ble
  BLE.poll();
//every time the light intensity (LDRread) goes under a value (200), it turns on the Nepoixel ring, otherwhise it stay, or switch it off
  if (!lowLight) { //if the light is off, check for environmental light value
    lightSense();
  if (BUTTONstate == HIGH){ //if button is pressed, the light sense code starts to run again
    lowLight = false;
  if (lowLight) {
    changeColor();
void blePeripheralConnectHandler(BLEDevice central) {
  //This is executed when connect
  Serial.print("Connected event, central: ");
  Serial.println(central.address());
void blePeripheralDisconnectHandler(BLEDevice central) {
  //This is executed when disconnect
  Serial.print("Disconnected event, central: ");
void protopieCharacteristicWritten(BLEDevice central, BLECharacteristic characteristic) {
  //Here I received from ProtoPie
  Serial.println("Characteristic received");
  String val;
  val = protopieCharacteristic.value();
  if (lowLight){
    if (val=="BREATHINGMODE10") {
      Serial.println(val);
      interval = 10000;
      breathingMode();
    else if (val== "BREATHINGMODE30") {
      interval = 30000;
      breathingMode();
    else if (val=="OFF")
///////////////BREATHING MODE ACTIVATION///////////////
void breathingMode() {
  colorWipe(pixels.Color(255, 0, 0), 50); //when breathing mode is activated, wipe to this color
  unsigned long startMillis = millis(); //millis when the action is triggered
  while (breathingModeActivation = true) {
    if ((unsigned long)(currentMillis - startMillis) <= interval) { //if time elapsed (currentMillis - startMillis) is lower than breathing mode duration, repeat
      updateBreath();
      } else if ((unsigned long)(currentMillis - startMillis) > interval) { //if time elapsed (currentMillis - startMillis) is higher than breathing mode duration, turn off breathing mode
        colorWipe(pixels.Color(255, 255, 255), 50);
///////////////BREATH///////////////
// breathing pixel variables
unsigned long startTime = 0;
int colorR = 0, colorG = 0, colorB = 0;
int breathTime = 6000; // 6000ms = six seconds; breathing speed
float breathTimeFloat = breathTime;
float pi = 3.14;
void updateBreath(){
  const float pi = 3.14;
  float frac; // ratio of color to use, based on time
  int r, g, b;
  // calculate a brightness fraction, based on a sine curve changing over time from 0 to 1 and back
  frac = (sin((((millis() - startTime) % breathTime)/breathTimeFloat - 0.25f) * 2.0f * pi) + 1.0f)/2.0f;
  // multiply each color by the brightness fraction
  r = 255 * frac;
  g = 0 * frac;
  b = 0 * frac;
  setPixelColor(pixels.Color(r, g, b), 50);
  BLE.poll();
helium97:
I’m not familiar with BLE but I suspect the answer to the problem is to use IF rather than WHILE and allow loop() to do the iteration.
…R
I tried to change "while" with "if", but I need that when the code in the while loop runs, everything else (except the bluetooth reading) doesn't run.
helium97:
You need to post the updated version of your program. It's not as simple as replacing the word "while" with the word '"if"
...R
Ok, this is it. I’ve changed the while with the if and added the modeActive bool in order to avoid everything else when the BREATHING MODE function is activated. The problem is that now, when the function is called, the LEDs remain stucked to the initial color, without doing the “breathing effect”.
This is the updated code:
int LDR = A0;
int LDRread = 0;
int BUTTON = 2;
int brBUTTON = 4;
long timePass = 0;
int currVal = 0;
int lastVal = 0;
///////////////RELAXING MODE VARIABLES////////////////
bool northernLightsModeActivation = false;
bool sunsetModeActivation = false;
bool nebulaModeActivation = false;
int curbrVal = 0;
int lastbrVal = 0;
int interval; // duration of the different "modes"
bool modeActive = false;
#define PIN 6
///////////////CAPACITIVE TOUCH SENSOR VARIABLES////////////////
CapacitiveSensor TouchSensor = CapacitiveSensor(11, 12);
long val;
int pos;
int showType = 0;
  pixels.begin();
  pixels.show();
  if (!BLE.begin()) {
  BLE.advertise();
  if (!lowLight) {
  //Check ble
  BLE.poll();
    if (!modeActive) {
      lightSense();
    lowLight = false;
  if (lowLight) {
    if (!modeActive) {
      changeColor();
  String val;
  if (lowLight){
        modeActive = true;
        interval = 10000; // duration
        breathingMode();
      if (val=="BREATHINGMODE30") {
        modeActive = true;
        interval = 30000; // duration
        breathingMode();
     if (modeActive) {
      if (val=="OFF") {
        modeActive = false;
  if (breathingModeActivation == true) {
      updateBreath();
        modeActive = false;
///////////////BREATH EFFECT///////////////
unsigned long startTime = millis();
float pi = 3.14;
  int r, g, b;
  r = 255 * frac;
  g = 0 * frac;
  b = 0 * frac;
void setPixelColor(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<pixels.numPixels(); i++) { //  ******i=0 - 0 is the start pixel
pixels.setPixelColor(i, c);       // *****change i to led\pixel number
//delay(wait);  // ************ removing eliminated the chase effect
  pixels.show();
I see this line in your program
but I don't see any code that actually sets that value to true.
That is not what the code does. Read your code carefully.
More importantly the reason for using IF rather than WHILE is to ensure that everything else can work. If you really do need to prevent other things from happening then WHILE may be appropriate.
...R
Robin2:
Thank you, I forgot to insert the code that sets the value to true. This is it:
        modeActive = true;
        breathingModeActivation = true;
        breathingMode();
Robin2:
That's the point. I think that the WHILE loop is appropriate in order to achieve the "breathing effect", and it works. The problem is that when Arduino enters in the WHILE loop, it stops to check the bluetooth connection, but I need it to keep checking (only) the bluetooth connection when it is in the "Breathing Mode", because I want it to be able to receive the "OFF" command (and then exit the loop).
helium97:
Snippets without the complete program are no use.
I think it's time for you to describe in English (not code) what this project is required to do.
Personally I see no conflict between using IF (properly) so that other parts of the code can be checked even if the main action should be confined to a particular area.
Have a look at how the code is organized in Several Things at a Time
Note how each function runs very briefly and returns to loop() so the next one can be called. None of the functions tries to complete a task in one call. And there may be dozens of calls to a function before it is actually time for it to do anything.
...R
