I'm trying to prepare simple application on NodeMCU (ESP 8266) with microSD card reader.
The idea is very simple.
I want to read microSD card content structure (dir and files) and store it in the memory for later purposes.
I've prepare following code
#include <Arduino.h>
#include <SPI.h>
#include <SD.h>
struct FileItem {
bool isDir;
const char* name;
FileItem* upDir;
std::vector<FileItem> elements;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1)
Serial.println("initialization done.");
Serial.println("Creating structure of files");
File root = SD.open("/");
FileItem rootItem;
rootItem.name = "/";
rootItem.isDir = true;
readSdCard(root, rootItem);
displaySdCardContent(rootItem, 0);
void readSdCard(File dir, FileItem& parentItem) {
while (true) {
File entry = dir.openNextFile();
if (!entry) {
break; // no more files
FileItem item;
item.isDir = entry.isDirectory();
item.name = entry.fullName();
parentItem.elements.push_back(item);
Serial.printf("Add %s to %s\n", item.name, parentItem.name);
if (entry.isDirectory()) {
readSdCard(entry, item);
void displaySdCardContent(FileItem& item, int numTabs) {
for (int i = 0; i < numTabs; i++) { Serial.print('\t'); }
if (item.isDir) {
Serial.printf("D %s (%s)\n", String(item.name), String(item.elements.size()));
for (FileItem fileElement : item.elements) {
displaySdCardContent(fileElement, numTabs + 1);
Serial.printf("F %s", item.name);
Where readSdCard reads all SD card content and store it in the struct FileItem.
Later displaySdCardContent displays information stored in the FileItem
What I can see in the logs is
readSdCardmethod reads data correctly from SD card (at least this is displayed in the Serial console)- method
displaySdCardContentworks weird. It displays incorrect name of the directory andelementsin theFileItemlooks like is empty.
I've spend already couple of hours on it and have no idea why it behaves like that
The output in the console is
21:42:25.794 -> Creating structure of files
21:42:25.823 -> Add Directory01 to /
21:42:25.855 -> Add Directory01/Directory01-01 to Directory01
21:42:25.888 -> Add Directory01/Directory01-01/02.txt to Directory01/Directory01-01
21:42:25.954 -> Add Directory01/Directory01-01/01.txt to Directory01/Directory01-01
21:42:26.020 -> Add Directory01/Directory01-01/03.txt to Directory01/Directory01-01
21:42:26.088 -> Add Directory01/Directory01-02 to Directory01
21:42:26.154 -> Add Directory01/Directory01-02/03.txt to Directory01/Directory01-02
21:42:26.219 -> Add Directory01/Directory01-02/01.txt to Directory01/Directory01-02
21:42:26.286 -> Add Directory01/Directory01-02/02.txt to Directory01/Directory01-02
21:42:26.352 -> Add .Trashes to /
21:42:26.385 -> Add .Trashes/501 to .Trashes
21:42:26.417 -> Add .Trashes/._501 to .Trashes
21:42:26.449 -> D / (2)
21:42:26.449 -> D [<shes (0)
