First post. Been working on this problem for many days.
I have a file of telephone numbers on a SD. I need to compare that data to find out if a specific telephone number is in that file. Simple right?
I have a test sketch and have exhausted 'Google', 'Yahoo' and 'Bing' to find a answer. I have tried every example I can find and nothing works. I want to read data into an array in memory for speed but maybe that is not the way to do it.
Not sure my approach to problem is even close to what I need. Can someone point me in the right direction? I am using a DUE and should have enough memory.
Thanks, joelaw
sketch:::
#include <SD.h>
File myFile;
char Records[6200]; //String array to hold records
char inchar; //Temp variable to hold next char
int n = 0; //index variable
while (!Serial)
Serial.print("Initializing SD card...");
pinMode(53, OUTPUT); //DUE pin 53 is chip select
if (!SD.begin(53)) //DUE pin 53 is chip select
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// read all records into memory array "Records"
myFile = SD.open("BlkList.log", FILE_READ);
if (myFile)
Serial.println("FileName = BlkList.log");
// read sd data file into Records Array
while (myFile.available())
inchar = myFile.read();
Records[n] = inchar;
n++;
myFile.close();
} else
Serial.print("ERROR..... opening BlkList.log");
findNum(); //function to do lookup for telephone number
// do nothing
void findNum() //function to do lookup for telephone number
// test example phone number
String phoneNum = "2532452465\n\r"; //full phone number
String AC = "253"; //area code only
for(int x=0; x < 6180; x + 3)
String ac = char((Records[x]+ Records[x+1] + Records[x+2])); // + etc.
if (AC == ac )
Serial.print("Found : ");
Serial.println(AC);
Serial.println(ac);
}else
Serial.println("Not Found");
Welcome to the forum. Please read the beginning "sticky" posts that explain how to post code using code tags. It helps others help you.
You did not say how the program was failing. Is it not finding the area code? Are you sure it should? Only you know what is in your data file. It is also odd that your have a telephone number followed by \n\r. On Windows machines, it is the other way around, carriage return ('\r') + newline ('\n')
You should also abandon the String class and just use regular C strings.
This untested code should work:
#include <SD.h>
const int MAX_SIZE = 6200;
char Records[MAX_SIZE]; //String array to hold records
int nbChars; // file length, <= MAX_SIZE
while (!Serial)
return;
File myFile = SD.open("BlkList.log", FILE_READ);
if (myFile)
nbChars = 0;
Records[nbChars++] = myFile.read();
if( nbChars == MAX_SIZE )
// we are out of room, so stop reading
myFile.close();
} else
// do nothing
//String phoneNum = "2532452465\n\r"; //full phone number
char *AC = "253"; //area code only
for (int x = 0; x < nbChars; x++)
if(strncmp(Records+x, AC, sizeof(AC)) == 0)
Serial.print(AC);
Serial.print( " at position " );
Serial.println(x);
} else
OK blh64,
Sorry for not using code tags. My data file is a list of telephone numbers on SD in the format of
"1234567890 + \r\n". I have 514 records so far.
I am trying to build a telephone spam caller list and when there is a new call, I want to do a lookup of previous callers and see if they have called before. The new caller is placed into a String variable and then compared with the caller list that is in a array "Records array" in memory (for speed).
I see that your code is more dynamic and maybe faster but still does the same thing of loading the list into memory array. I want to compare the "Records array" with the new string. That is what I cannot seem to code right. The code "if(strncmp(Records+x, AC, sizeof(AC)) == 0)" comparison did not work. Can't find the matching string in Records array. I was trying to use only the area code first since it is only three characters. The line above that is commented out, is really what I want to compare.
I tried converting the caller list into two long variables and saving but I did not get that code to work either. The spam caller list is a list from multiple sources and the way I stored on the SD seemed to be OK.
The goal is simply to check a list for a new caller and see if they are on the list but, cannot find a way to do this (many, many hours wasted).
//#include <SD.h>
#define TEST_DATA
#ifdef TEST_DATA
const int MAX_SIZE = 620;
#else
#endif
while (!Serial);
#ifdef TEST_DATA
const char testData[] = "123456789\r\n2532452465\r\n234567890\r\n";
strcpy(Records, testData);
nbChars = sizeof(testData);
#else
while (1);
if (myFile)
nbChars = myFile.size();
if ( nbChars >= MAX_SIZE ) {
Serial.println( "File too large" );
while (1);
myFile.read( Records, MAX_SIZE);
myFile.close();
while (1);
#endif
Serial.println("Data loaded");
// do nothing
char seek[] = "2532452465\r\n"; //full phone number
const int nChars = sizeof(seek) - 1;
//char *AC = "253"; //area code only
Serial.print("nChars = " ); Serial.println(nChars);
bool found = false;
if (strncmp(Records + x, seek, nChars) == 0)
Serial.print(seek);
Serial.println(x);
found = true;
if ( !found ) Serial.println("Nothing Found");
The only real difference is the length parameter to strncpy() needs to be sizeof(seek)-1
The file is actually 6180 bytes since 12 chars times 515 records = 6180. It will grow.
You are not reading the file on SD into the Records array and then trying to find a 12 char number in that array. You only load the Records with the constant data (testData) which does make three records that can be compared.
What I can't get is how to compare this to a new string read from the incoming caller Id to what is loaded in the Records array. How does "char seek[]" get loaded? your testData is not a changing variable.
Could I read a string (telephone number) into testData and how? The test data in your code is a const not a variable?
