Read Serial Port from Arduino through Ethernet Shield
No need for help anymorew
Look up the Ethernet library and read.
You need the code
it is your choice.
You can setup small www-server on the board or sent your data to the external one.
But Uno may not have enough resources for ww-server
it only question of the software
Actually you don't need the LAN cable oil. They are slippery enough already.
You know, it could benefit others if you posted your solution instead of destroying your post.
Because people did actually try to help you.
Don't forget that you used the term "lan cable oil"; nobody knows what that is so you get a joke back.
What's answers do you expect? Just ready to go code for your task?
