read several characters in arduino mega
i have my mega board. i want to read for characters . whereas only 'one' character is read. All others are not.
here is the program:
#include <SPI.h>
DDRA = 0xff;
char one = Serial.read();
char two = Serial.read();
char three = Serial.read();
char four = Serial.read();
switch(one)
case '1':
PORTA = 0xFF; //THESE VALUES CAN BE VARIED AS YOU WANT
case '2':
PORTA = 0x00;
switch(two)
case '1':
case '2':
PORTA = 0x00;
switch(three)
case '1':
case '2':
PORTA = 0x00;
switch(four)
case '1':
case '2':
PORTA = 0x00;
You need to check if there are characters to read first.
if (Serial.available>3){ // 4 character ready?
then go into switch:case statememts.
Oops - syntax not quite correct:
Serial.available() >3
regards
vanashree
i have my code here where i am trying to read the variable value but it shows nothing in pin13. as i try to blink led 13 once the data is recvd..it compiles but doesnot go high low as it should upon reception of code i want to check wheather i am recvng propoer code and are there any mistakes in this program?
int led = 13;
char myarray[4] = {'A','B','C','D'}; // char of strings which i want to recv
char x;
int led = 13;
pinMode(led, OUTPUT);
char x;
int led = 13;
  while (Serial.available() > 0)
if (Serial.read() == 'A') // here i want to say that if my string starts with A it is recvd n stored in x
char x = Serial.read();
else if (Serial.read() == 'B') // here i want to say that if my string starts with B it is recvd n stored in y
char y = Serial.read();
else if (Serial.read() == 'C') // here i want to say that if my string starts with C it is recvd n stored in w
char w = Serial.read();
else if (Serial.read() == 'D') // here i want to say that if my string starts with D it is recvd n stored in z
char z = Serial.read();
if (char x = '1');
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
ACTUALLY,
IF there can be some way where i can read my x ,y,w,z, values? i tried doing serial.print(x);
the code is here:
char x;
char x;
Serial.print(x);
i just want to read what x has exactly?
help me to do so kindly suggst somehing and just make this prog running
:cold_sweat:
What are the chances that "x" is not -1, if the character that you knew was there was 'A'?
i didnt get u??
u said that:
can u elaborate?
i am sending A from serial monitor so from where -1 comes?
if trying to say something else kindly elaborate since i am a learner in arduino.
vanashree:
i didnt get u??
You are sending 1 character but you are trying to receive 2 characters by using Serial.read() twice.
Each time you call Serial.read() it removes a character from the input buffer. It returns -1 if the buffer is empty.
...R
vanashree:
i didnt get u??
u said that:
can u elaborate?
try this.
You will take one char from the serial buffer (if available) and if it matches any of your four letters or '1' it will behave accordingly.
int led = 13;
  if  (Serial.available())  // is there anything in the serial buffer?
    char myChar = Serial.read();
    if (myChar == 'A') // is the char you received an 'A' ??
      Serial.println(myChar);
    else if (myChar == 'B') // here i want to say that if my string starts with B it is recvd n stored in y
    else if (myChar == 'C') // here i want to say that if my string starts with C it is recvd n stored in w
    else if (myChar == 'D') // here i want to say that if my string starts with D it is recvd n stored in z
    if (myChar = '1');
A simple example of capturing characters sent from the serial monitor and operating the arduino LED.
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
  while (Serial.available()) {
    delay(3);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if (readString == "on")
      digitalWrite(ledPin, HIGH);
    if (readString == "off")
      digitalWrite(ledPin, LOW);
    readString="";
thanks i got it workig.i useda another logic n have attached my prog.
thanks a lot now its working.i just have one smaall isssue.and that is in last few if elese where on recving 1 or 2 or 3 in my 7th strin i want to make my respective pin high onlly for 2 seconds and then back to low until i recieve next codde.
i have posted my problem in new topic already.
full_prog_without_print.ino (11 KB)
