Read single sensor with 2 device
Bonjour
Quick question :
I do have an ADI Ocelot running my automation for almost 15 years now... The system is still have a very high WAF.
I am in a process of leaving X10 to Zigbee and Z-wave for some stuff... but the alarm system for the house is builted on Ocelot and is working very good,
I would like to monitor (for my hubitat interface) what is going on on the Ocelot without shutting it down.
Plan A was to put a wire between the Ocelot input port (from door and PIR sensors) and bring it direct to arduino. So arduino would see also the opening or closing of contact.... but it dosent.
The arduino port sees OPEN / CLOSED switching every half second (probably the refresh rate of Ocelot to go trought the script)... So I can't use the info from the port... It is worst with PIR, but door contact is not as bad.
It looks like that the Arduino is sensing the reading of the Ocelot...
I have connected my ground all toghter, I tought that was it. but it is not....
the script that I am using define the port as "STATIC"... for connecting to hubitat
So question : Am I trying to do something that can't be done electronically or is there something that I could try to solve and use both at the same time for the sensors?
My door sensor have a resistor betbeen the contact and the input terminal... I have tryed to connect before and after the resistor with no sucess.
Thank you
Luc
Your duplicate post in General Electronics has been deleted
Do not scatter the same question in multiple parts of the forum
