jremington:
Your photo, posted properly. See image posting guide.
Thanks for the info. I will keep this in mind in the future.
Of course you forgot to post a link to the "solar charger", but if the two "-" connections are common on the charger module, the ground connection in red is already made.
Do yourself a favor and get a decent multimeter, so that you can check voltages, continuity and resistance.
It is a small chinese generic charger and does not come with a manual. The positives are connected together as mentioned in Wawa's post below. I don't know which resistances you want me to measure or why but the solar-to-battery resistance is about 17 Kohm and battery-to-load resistance is 24 Kohm. The solar panel rating is 15 Watts, max 18 Volts and the battery is 12 volts.
Do not use a lithium based battery in this circuit, if the battery is also loaded. There are no charger modules on the hobby market that can safely charge a lithium battery under load.
I am aware of this. I am using a small lead acid battery. Thanks for the warning though.
Wawa:
Solar chargers can have a common negative, but more often a common positive.
Measure it.
Yes, you are right in my case; the positives are connected together.
But why are you interested in solar 'voltage', which is somewhat irrelevant.
I would measure battery voltage (negative to Arduino ground), and solar/charging current (high-side).
That could be done with an INA226 breakout board.
I would like to measure solar panel voltage and current so that I can calculate solar radiation as per this.
Can you please explain what do you mean by "solar/charging current (high-side)"? Do you mean the current from the solar panel?
Thanks for the replies.
