Maybe you've thought about how to reading sensor data and display it to a web page in realtime with or without jQuery?
For communication from Arduino UNO to PC, i use VBS (Visual Basic Script) This is an Example Script to store data into MySQL:
' The MySQL query
Set objShell = CreateObject( "WScript.Shell" )
' Store Data to MySql, make sure the mysql path you are using is correct
Return = objShell.Run( "C:\wamp64\bin\mysql\mysql8.0.21\bin\mysql -hlocalhost -uroot arduino -e " _
& chr(34) & "INSERT INTO `dht11` (`humi`, `tempc`, `tempf`) VALUES ('10', '20', '30')", 1, false )
wscript.Sleep 500
And here is the complete script (Visual Basic Script) to Read & Store data into MySql ( 'readSerial.vbs'
on error resume next
Const ForReading = 1
Const ForWriting = 2
dim port, data
' get COM port number from the user
port = InputBox( "Enter COM Port Number (e.g: COM1, COM2, COM3)" )
Set wshell = CreateObject( "WScript.Shell" )
Set fso = CreateObject( "Scripting.FileSystemObject" )
Set com = fso.OpenTextFile( port & ":9600,N,8,1", ForReading )
MsgBox( "Start to read data from " & port )
Do While com.AtEndOfStream <> True
' Humidity & Temperature Data
data = com.ReadLine
& chr(34) & "INSERT INTO `dht11` (`humi`, `tempc`, `tempf`) VALUES (" & data & ")" & chr(34), 1, false )
WScript.Sleep( 200 )
Loop
com.Close()
Schematics or circuit diagrams:
And this is the Scatch that you need to upload to Arduino UNO:
* Created by ArduinoGetStarted.com
* This example code is in the public domain
* Tutorial page: https://arduinogetstarted.com/tutorials/arduino-temperature-humidity-sensor
#include "DHT.h"
#define DHTPIN 3
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
const int buzzer = 2; // buzzer to arduino pin 2
float oHumi, humi, oTempC, tempC, oTempF, tempF;
// Serial.println("DHT sensor test!");
// Serial.println("================");
dht.begin(); // initialize the sensor
// wait a few seconds between measurements.
delay(2000);
// read humidity
humi = dht.readHumidity();
// read temperature as Celsius
tempC = dht.readTemperature();
// read temperature as Fahrenheit
tempF = dht.readTemperature(true);
// compare value
if ( oHumi != humi || oTempC != tempC || oTempF != tempF ) tempChanged();
void playTone() {
tone(buzzer, 600); // Send 1KHz sound signal...
delay(100); // ...for 1 sec
noTone(buzzer); // Stop sound...
delay(100); // ...for 1sec
void tempChanged() {
// check if any reads failed
if (isnan(humi) || isnan(tempC) || isnan(tempF)) {
Serial.println("Failed to read from DHT sensor!");
String data = (String) "'" + round(humi) + "', '" + round(tempC) + "', '" + round(tempF) + "'";
Serial.println( data );
playTone();
// Save old results
oHumi = humi;
oTempC = tempC;
oTempF = tempF;
Visit https://github.com/arduino-uno for more ..
dht11.ino (1.54 KB)
webdemo.zip (2.81 KB)
readSerial.vbs.txt (829 Bytes)
