Read Suzuki Vitara Tacho meter
Hi everyone,
I wanted to DIY a tachometer using arduino for my Suzuki Vitara JLX 1997.
The current wiring diagram in my car is "Ignitor -> noise supressor signal -> tachometer/ecu"
Is there a way to read the signal without interfering the existing circuit in the car?
Hi, @chewyuinyee
Welcome to the forum.
Thanks for the car wiring diagram.
Have you Googled;
arduino tachometer car ignition
Tom.... :smiley: :+1: :coffee: :australia:
Hi Tom,
I did come across this diagram.
But I not sure how it will impact the ECU or Tacho display in the existing system in my car.
It is possible to just "TACH_SIGNAL" directly to the brown wire ?
Possibly not as that brown wire has a series capacitor filter circuit in series.
The brown circuit might be loaded down by the input of the circuit you have in post #3.
It is meant to connect directly to the coil, but i am not mistaken, it should be on the GND side, where the induction of the coil triggers the opto-coupler.
