How to read the digital pin number when its ON - HIGH. But not the state?
Are you trying to read the state of an input pin or output pin?
Perhaps he wants to know which pins are ON.
Or the state of a particular pin (ON or OFF).
The digital pins are numbered from 0 to 13.
When one of these is ON-HIGH wish to read which is the number of Pin.
I NOT wish to read the state of Pin but knowing the Pin number.
You could try this (untested) to determine which pins are currently HIGH:
Incidentally, "ON" or "HIGH" is the state of the pin. It is necessary to read the state of the pin in order to meet your requirement for printing it out.
Serial.begin( 9600 ) ;
for ( int i = 0 ; i <= 13 ; i++ ) {
pinMode( i, INPUT_PULLUP ) ; // or maybe just INPUT
if ( digitalRead( i ) == HIGH ) {
Serial.print( "pin is now HIGH: ") ;
Serial.println( i ) ;
delay(2000);
I was bored
The "state[]" array holds the state of pins 0-13. Traverse the array to see which pins are high (1) or low (0). Also outputs to serial port
// Set as inputs
DDRD = 0;
DDRB = 0;
// (Optional) enable pullups
PORTD = 0xFF;
PORTB = 0x3F;
// Read inputs
int inputs = PIND + (PINB & 0x3F)*256;
int state[13];
// Parse out the high bits
for (int i = 0; i < 14; i++)
state[i] = ((inputs & (1 << i)) == 0) ? 0 : 1;
// Display
for (int j = 0; j < 14; j++)
if (state[j] == 1)
Serial.println(j);
