Hello, I have a raspberry with MOSQUITTO installed. I am trying to read topics values when Arduino restart or reconnect but it doesn't work.
// FUNCION PARA MQTT
void callback(char* topic, byte* message, unsigned int length) {
Serial.print("Message arrived on topic: ");
Serial.print(topic);
Serial.print(". Message: ");
String messageTemp;
for (int i = 0; i < length; i++) {
Serial.print((char)message[i]);
messageTemp += (char)message[i];
Serial.print("messageTemp: ");
Serial.println(messageTemp);
// Changes the output state according to the message
modo_ai = messageTemp.toInt();
Serial.print("Changing modo_ai to ");
Serial.println(modo_ai);
void sendDataTopic()
client.publish( MQTT_SERIAL_PUBLISH_CH "acu/agua", String(temp_agua).c_str());
client.publish( MQTT_SERIAL_PUBLISH_CH "acu/habitacion", String(tempHB).c_str());
// FUNCION PARA RECONECTAR
void reconnectWifi() {
Serial.println("Iniciar conexión a la red WIFI");
while(status != WL_CONNECTED) {
Serial.print("Intentando conectarse a WPA SSID: ");
Serial.println(ssid);
//Conectar a red WPA/WPA2
status = WiFi.begin(ssid, pass);
Serial.println("Conectado a la red WIFI");
void reconnectClient() {
// Loop until we're reconnected
while (!client.connected()) {
delay(200);
Serial.print("Attempting MQTT connection...");
// Create a random client ID
String clientId = "ESP32Client-";
clientId += String(random(0xffff), HEX);
Serial.println(clientId.c_str());
// Attempt to connect
if (client.connect(clientId.c_str(),mqttUser,mqttPassword)) {
Serial.println("connected");
//Once connected, publish an announcement...
client.publish(MQTT_SERIAL_PUBLISH_CH "acu/status", "conectado!");
// ... and resubscribe
client.subscribe("acu/modo_ai");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
//Validamos si el modulo WiFi aun esta conectado a la red //Si falla la conexión, reconectamos el modulo
status = WiFi.status();
if(status != WL_CONNECTED) {
reconnectWifi();
//Validamos si esta la conexión del servidor //Si falla reintentamos la conexión
if(!client.connected() ) {
reconnectClient();
delay(100);
// cliente a la escucha
client.loop();
#ifdef CONTADOR
contador_1 ++; // Serial.print(contador_global);
if (contador_1 == 20) {
//Serial.println("contador 20");
check_temp(); // Comprueba valores temperatura
if (contador_1 == 40) {
// Serial.println("contador 40");
check_ventilador(); // Comprueba si activa ventilador
if (contador_1 == 60) {
// Serial.println("contador 60");
check_calentador(); // Comprueba si activa el calentador
check_UV(); // Comprobamos horario para encender UV
check_ai(); // Comprobamos horario para encender AIREADOR
if (contador_1 == 100) {
Serial.println("contador 100 y 0");
sendDataTopic(); // Envia datos a mqtt
#ifdef pantalla
// ############## Inicio "picture loop" #######
u8g2.firstPage();
do {
draw();
} while( u8g2.nextPage() );
// ############## Fin "picture loop" ##########
#endif
contador_1 = 0;
#endif
// peris(); // comprueba peristalticas
check_nivel_acu(); // Comprobamos el nivel del agua del acuario
for example, in MQTT value of mod_ai=3 but when I restart Arduino It load as 0. Then if I change value in MQTT it updates in Arduino.
