read tty while writing to a file
(how can i merge the following to playground/LinuxTTY?)
cat </dev/ttyACM0 > test |tee or
tee test < /dev/ttyACM0
EDIT1: the above don’t always work. I’m trying to find a way to use tee
I’ll stick with :
cu -l /dev/ttyACM0 -s 9600 | tee temp.txt which can be stopped with :
pkill cu.
Now, the DRAWBACKS are :
  • it doesn’t stop with Ctrl+c
  • it needs some cleanup in the head and the tail
EDIT3: to clean up just do :
head -n -4 temp.txt > output.txt afterwards :slight_smile:
