Read .txt file which is placed on external webserver
Hello,
I want to read the content of a text-file, which is put on "my" webserver at a webhosting platform (square7). In this text-file is ONE number "0", or "1", etc.. I have a Arduino Uno board with attached WiFi-SHD as µ-controller, which should read the data and turn a LED on if the number in the textfile equals "1".
So how can I read this text file placed on the server?
Thx in advance!
Check the examples of the ethernet lib / wifi lib.
there is a webclient that does 99% of what you need.
Basic client code that downloads a file.
//zoomkat 9-22-12
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
//remove SD card if inserted
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "web.comporium.net"; // zoomkat's test web page server
EthernetClient client;
void setup(){
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  Serial.println("Better client test 9/22/12"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.1"); //download text
    client.println("Host: web.comporium.net");
    client.println("Connection: close");  //close 1.1 persistent connection
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
@zoomkat: Thanks a lot for your useful reply, I had a similar code tested but forgot the "client.available()" syntax :slight_smile:
Now I just have to shrink the request so that only the first byte is readed, but I think I'll manage this :wink:
zoomkat:
//zoomkat 9-22-12
#include <SPI.h>
void setup(){
    while(true);
void loop(){
  else {
So this works already, but the request sends following as well:
Read Server data..
connected
HTTP/1.1 200 OK
Date: Wed, 05 Mar 2014 09:10:49 GMT
Server: Apache/2.4
Last-Modified: Wed, 05 Mar 2014 09:10:00 GMT
ETag: "1-4f3d862a44adc"
Accept-Ranges: bytes
Content-Length: 1
Connection: close
Content-Type: text/plain
1
And so I can't check, if the text in the file is "1", because when I do a if() request, the complete answer of the server is given and not only the latter 1...
However, how can I ingore the header and only compare the content of the text file?
Thanks in advance!
