read value from function
Hai all
i have question how i want to read the value from other function and store to other function. here i attach the source code.
#include "Wire.h"
#define q1 37
#define q2 38
#define q4 39
#define q8 40
 Wire.begin(); // join i2c bus (address optional for master)
 pinMode(q1, INPUT); // thumbwheel '1'
 pinMode(q2, INPUT); // thumbwheel '2'
 pinMode(q4, INPUT); // thumbwheel '4'
 pinMode(q8, INPUT); // thumbwheel '8'
int readSwitch()
 int total=0;
 if (digitalRead(q1)==HIGH) { total+=1; }
 if (digitalRead(q2)==HIGH) { total+=2; }
 if (digitalRead(q4)==HIGH) { total+=4; }
 if (digitalRead(q8)==HIGH) { total+=8; }
 return total;
 int cycleTimer(digitalRead(readSwitch()));
 int mulTimer = cycleTimer * 1000;
 Serial.println(readSwitch()); // sends switch value to serial monitor box
 delay(mulTimer);
delay value will equal with the mulTimer but i cannot get the exact value for delay. it give one second only. can anybody help me to solve this problem.
thanks
Saripdol
I don’t understand. This bit:
implies that readSwitch() will return a pin number to be used with digitalRead. But it looks like it actually reads a bunch of pins and comes up with some other number.
Did you mean
int cycleTimer = readSwitch();
maybe?
Delta_G:
I don't understand. This bit:
Did you mean
maybe?
yes i want readSwitch () value store in cylceTimer.
OK, well I don't know what you had going on with that digitalRead and all then. If you just want the value returned to go into a variable then you just need the equal sign there.
