Read Variable value from SDcard
Hi guys, I need help with this question, How can I make for read one value from SDcard and pass to a variable? I already recorded the value of a variable on SDcard, on the following example, recorded the pin value of exit from led, now supposing that I want read the value for the exit pin from SDcard, how can I do this ?
Thanks for any help. :slight_smile:
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
#include <SD.h>
File myFile;
int led = 10;
// the setup routine runs once when you press reset:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
if (SD.exists("test.txt")) {
SD.remove("test.txt"); //We don't want to use the same file THIS IS THE BUG?
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println(led);
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// re-open the file for reading:
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(5000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
Maybe if you add a few more useless curly braces yo your code and don't bother with proper formatting, things will get better.
Using code tags doesn't apply to you, either. Or does it?
Check #7 below
http://arduino.cc/forum/index.php/topic,148850.0.html
