I am trying to read the feedback from VDIP with my mega in order to react to upcoming error messages.
I used the arduino playground code and modified it with PSTRING to put the serial feedback into a container. But compiling it gives an error all the time:
In function 'void loop()':
error: 'mess' was not declared in this scop
Does anyone have an idea what I did wrong?
#include <PString.h>
int incomingByte=0;
int fileNumber=1;
int noOfChars;
long int valToWrite;
char activityToLog;
long int x;
long int startLogTime = 0;
int vdippower = 52; // LED connected to digital pin 13
char vdipreturnmassage;
char vdipreturnmessagebuffer[40];
pinMode(vdippower, OUTPUT);
digitalWrite(vdippower, HIGH);
delay(1500);
Serial1.begin(9600);
Serial1.print("IPA");
Serial1.print(13, BYTE);
Serial.println("Setupdone");
int incoming = 0;
if (Serial.available()) {
incoming = Serial.read();
if (incoming =='1'){
Serial1.print("DIR");
incoming = 0;
if (incoming=='2'){
Serial1.print("OPW test1"); // open to write creates a file - named
//Serial1.print("nochmaltest"); // LOG%1.TXT first time round - .TXT is for the computer
Serial1.print(".TXT"); // I have used the % sign in the name so I can
//search the disk for log files that it has created
//so as not to overwrite any that may be on already
Serial1.print(13, BYTE); // return character
for (int i=0; i <= 5; i++){
valToWrite=millis() - startLogTime; // time since we started logging
noOfChars=1;
x=valToWrite; // need to copy valToWrite as getting no of characters will consume it
while (x>= 10){ // counts the characters in the number
noOfChars++; // thanks to D Mellis for this bit
x/=10;
noOfChars +=1; //add 2 to the num as will also write the letter P and a return character
Serial1.print("WRF "); //write to file (file needs to have been opened to write first)
Serial1.print(noOfChars); //needs to then be told how many characters will be written
Serial1.print(13, BYTE); //return to say command is finished
Serial1.print(valToWrite);
Serial1.print(13, BYTE); //write a return to the contents of the file (so each entry appears on a new line)
delay(300);}
Serial1.print("CLF test1"); // it closes the file
if (Serial1.available()) {
PString mess(vdipreturnmessagebuffer, sizeof(vdipreturnmessagebuffer));
Serial.print((char)Serial1.read());
mess += ((char)Serial1.read());
//Serial.println(mess);
[glow]if (mess == "Ver 03.66VDAPF On-Line:Device Detected P2No Upgrade" {[/glow]
Serial.println("joot");
