I am trying to implement a storage for data from sensors to avoid the array limitations of the inherent EEPROM. I purchased the MKR memory board with 2MB of storage which is more than sufficient.
My thoughts were to create a small routine that would take a floating point number which I know to be 32-bits in size and by shifting that number sequentially by 24, 26, 8, and 0 I could assign the lowest 8 bits of the number to an unsigned char array. This array could then be passed to the SPI.h library for sequential writes of 4 bytes to a beginning address. Of course in my dreams and aspirations the reverse would be to read 4 addresses and build a 32 bit float by shifting bits into a float.
I am beginning to believe that the only real way to do this is to accept precision to 2 (0.00) decimals, multiply by 100 and convert to an unsigned long.
Any thoughts?
union
float x = 1.23;
byte dataArray[4]; //3F9D70A4; dataArray[0] = A4
} myData;
Thanks to both of you. I am currently exploring the "union" as I had not been introduced to it many years ago when I coded for a living.
lavignema:
(1) When we declare float x = 1.23;, the compiler automatically stores this 3F9D70A4 32-bit pattern into 4 consecutive memory locations as per binary32 format of IEEE-754 Standard.
(2) When we declare the following union data structure, a 4-byte wide buffer space is shared by both of these two variables: x and dataArray[4]. The 32-bit value of x becomes available to the user as separate 4-byte via the members of the dataArray[]. The lower indexed member of the array contains the lower byte of the 32-bit value. In union, we define only one variable whose value is automatically taken care of by other variables according to their data types.
union
float x = 1.23;
byte dataArray[4]; //3F9D70A4; dataArray[0] = A4; dataArray[1] = 70; dataArray[2] =9D, ... ,
} myData;
(3) To access the individual bytes of the dataArray, we use the following commands:
byte x0 = myData.dataArray[0];
byte x1 = myData.dataArray[1];
byte x2 = myData.dataArray[2];
byte x3 = myData.dataArray[3];
(4) The 32-bit value of x can be printed on the Serial Monitor by executing the following codes:
long *ptr;
ptr = (long*) &myData.x;
long m = *ptr;
Serial.println(m, HEX); //Serial Monitor shows: 3F9D70A4
(5) The byte-wise components of the 32-bit value of float x = 1.23; can be found by executing the following codes (without using union):
float x = 1.23;
byte *ptr;
ptr = (byte*) &x;
byte m0 = *ptr; //lower byte
Serial.println(m0, HEX);
ptr++;
byte m1 = *ptr;
Serial.println(m1, HEX);
ptr++;
byte m2 = *ptr;
Serial.println(m2, HEX);
ptr++;
byte m3 = *ptr;
Serial.println(m3, HEX); //most significant byte
Thanks, this works so well.
