hye..
i am new in arduino and i have a problem in using it. i hope you can help me.
my project is make a program to the rain gauge which is every count of 'tick' in the rain gauge will be write in the SD card.
this is my coding that i have try using SDuFat..
#include <SdFat.h>
#include <SdFatUtil.h>
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
int powerSD = 8;
int ledPin = 13; // For monitoring purpose only if action occur
int pushButton = 9; // Set this to RainGauge Sensor Pin
int pushButtonState = 0; // monitor the State of RainGaugeState,
int val = 0;
int lastButtonState = 0; // To compare with current state
// Eliminate repeating status on same state
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char *str)
PgmPrint("error: ");
SerialPrintln_P(str);
if (card.errorCode())
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(), HEX);
while(1);
// Write Carriage Return/Line Feed to a file
void writeCRLF(SdFile &f)
f.write((uint8_t *)"\r\n", 2);
// Write an unsigned number to a file
void writeNumber(SdFile &f, uint32_t n)
uint8_t buf[10];
uint8_t i = 0;
do {
i++;
buf[sizeof(buf) - i] = n%10 + '0';
n /= 10;
} while (n);
f.write(&buf[sizeof(buf) - i], i);
// Write a string to a file
void writeString(SdFile &f, char *str)
uint8_t n;
for (n = 0; str[n]; n++);
f.write((uint8_t *)str, n);
// initialize the digital pin as an output:
pinMode(powerSD, OUTPUT);
//pinMode(pushButton, INPUT);
Serial.println("Type any character to start");
while (!Serial.available());
if (!card.init()) error("card.init"); // initialize the SD card
if (!volume.init(card)) error("volume.init"); // initialize a FAT volume
if (!root.openRoot(volume)) error("openRoot"); // open the root directory
// create a new file
char name[] = "WRITE00.TXT";
for (uint8_t i = 0; i < 100; i++) {
name[5] = i/10 + '0';
name[6] = i%10 + '0';
if (file.open(root, name, O_CREAT | O_EXCL | O_WRITE)) break;
if (!file.isOpen()) error ("file.create");
Serial.print("Writing to: ");
Serial.println(name);
pushButtonState = digitalRead(pushButton);
if(pushButtonState != lastButtonState)
if (pushButtonState == HIGH )
digitalWrite(ledPin, pushButtonState);
delay(250);
writeString(file, " millis = ");
writeNumber(file, millis());
writeCRLF(file);
lastButtonState = pushButtonState;
digitalWrite(ledPin, LOW); // set the LED off
delay(200);
// close file and force write of all data to the SD card
file.close();
Serial.println("Done");
void loop(void) {}
this code have no error but it give me a result of SD card not initialized. like this...
error: card.init
SD error: 1,FF
for your knowledge, i am using arduino duemilanove atMega168 and Libelium MicroSD module.
