READ / WRITE ini files
HI,
I want to save data on an SD card. I use an INI file... with the library of Steve Marple (https://github.com/stevemarple/IniFile) It is perfect to read the data But how can I change something in this INI file.. I see that this library can not do that.
Is there anyone who can help me to implement this 'write' function??
Why not? Once you've read all the data, you have everything you need to re-write the file containing exactly the same data.
Making changes, and writing the file using different data, is trivial.
Where IS your code?
PaulS:
Doesn’t take this a long time to write a whole new file… I though it can be done by just write the new variabele to the new key in the INI-file.
I can read ONE key from the file, so it should be possible to write (change) ONE key in the same file…
PaulS:
Where IS your code?
This is the INI file:
[item1]
text = Light Kitchen
type = 1
[item2]
text = Light bedroom
type = 0
[item3]
text = test3
type = 4
[Options]
tempOutside = 1
tempInside = 1
This is the Arduino Code:
#include <IniFile.h>
#define SD_SELECT 4
#define ETHERNET_SELECT 53
void printErrorMessage(uint8_t e, bool eol = true)
  switch (e) {
  case IniFile::errorNoError:
    Serial.print("no error");
  case IniFile::errorFileNotFound:
    Serial.print("file not found");
  case IniFile::errorFileNotOpen:
    Serial.print("file not open");
  case IniFile::errorBufferTooSmall:
    Serial.print("buffer too small");
  case IniFile::errorSeekError:
    Serial.print("seek error");
  case IniFile::errorSectionNotFound:
    Serial.print("section not found");
  case IniFile::errorKeyNotFound:
    Serial.print("key not found");
  case IniFile::errorEndOfFile:
    Serial.print("end of file");
  case IniFile::errorUnknownError:
    Serial.print("unknown error");
  default:
    Serial.print("unknown error value");
  if (eol)
  // Configure all of the SPI select pins as outputs and make SPI
  // devices inactive, otherwise the earlier init routines may fail
  // for devices which have not yet been configured.
  pinMode(SD_SELECT, OUTPUT);
  digitalWrite(SD_SELECT, HIGH); // disable SD card
  pinMode(ETHERNET_SELECT, OUTPUT);
  digitalWrite(ETHERNET_SELECT, HIGH); // disable Ethernet
  const size_t bufferLen = 80;
  char buffer[bufferLen];
  const char *filename = "config.ini";
  SPI.begin();
  if (!SD.begin(SD_SELECT))
    while (1)
      Serial.println("SD.begin() failed");
  IniFile ini(filename);
  if (!ini.open()) {
    Serial.print("ERROR - Ini file ");
    Serial.print(filename);
    Serial.println(" does not exist");
    // Cannot do anything else
    while (1)
  Serial.print("SUCCESS - Found ");
  Serial.println(" file.");
  // Check the file is valid. This can be used to warn if any lines
  // are longer than the buffer.
  if (!ini.validate(buffer, bufferLen)) {
    Serial.print("ini file ");
    Serial.print(ini.getFilename());
    Serial.print(" not valid: ");
    printErrorMessage(ini.getError());
    while (1)
  // Fetch a value from a key which is present
  if (ini.getValue("item1", "text", buffer, bufferLen)) {
    Serial.print("section 'item1' has an entry 'text' with value ");
    Serial.println(buffer);
  else {
    Serial.print("Could not read 'text' from section 'item1', error was ");
  if (ini.getValue("item1", "type", buffer, bufferLen)) {
    Serial.print("section 'item1' has an entry 'type' with value ");
  else {
    Serial.print("Could not read 'type' from section 'item1', error was ");
    if (ini.getValue("item2", "text", buffer, bufferLen)) {
    Serial.print("section 'item2' has an entry 'text' with value ");
  else {
    if (ini.getValue("item2", "type", buffer, bufferLen)) {
    Serial.print("section 'item2' has an entry 'type' with value ");
  else {
    Serial.print("Could not read 'type' from section 'item2', error was ");
    if (ini.getValue("item3", "text", buffer, bufferLen)) {
    Serial.print("section 'item3' has an entry 'text' with value ");
  else {
    if (ini.getValue("item3", "type", buffer, bufferLen)) {
    Serial.print("section 'item3' has an entry 'type' with value ");
  else {
    Serial.print("Could not read 'type' from section 'item3', error was ");
void loop(){
//the rest of the code
Will changing the value change the length of the INI file? If so, making the change isn't a simple matter of just overwriting what's already there. If you think of a file in terms of it being a series of bytes written to a storage device, it becomes easier to understand why you just write out the whole thing.
