Read/Write Problem at an I2C EEPROM with LCD Display
Following my previous topic Cannot Read/Write to an 24LC256 EEPROM chip - Storage - Arduino Forum i tried adding to my project that has an lcd display of 20 columns and 4 rows the external EERPOM and read/write some data on it. More specifically i want (for starters) to have a value stored at the EEPROM (in my case it is 100) that will be used to dim the lcd display and later on i can change this value and store it at the external EEPROM. Even though the read/write code works as intended at the provided link, when i initialize the wire.h library the code freezes and the display shows 3 ' ' ' ' and it continues with garbage characters. I checked this by using only the command Wire.begin(); and the program froze as i mentioned before, when the Wire.begin(); is removed the program i have works as intended (without any option to read/write at the EEPROM)
The following code is part of the starting code i have along with the setup function and the read function for the EEPROM. i do not include the loop function since the problem is located at the setup function. The board i use is the Leonardo
Any help is much appreciated
#include <LiquidCrystal.h> //LCD Library
#include <MenuBackend.h>    //MenuBackend library - copyright by Alexander Brevig
#include <OneWire.h>            //Onewire Library
#include <DallasTemperature.h>  // Dallas library
#include <Wire.h>               //I2C Library for external EEPROM
#include "DHT.h"          // DHT Library
#define DHTPIN 8          // DHT sensor pin on arduino
#define DHTTYPE DHT22     // DHT22 sensor
#define ONE_WIRE_BUS 12         //pin where one bus sensor is connected
#define EEPROM_ADDRESS 0x50   //address for external EEPROM
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire); //Pass oneWire reference to Dallas Temperature.
DeviceAddress HeaterTemp = {
  0x28, 0x57, 0xFF, 0x08, 0x04, 0x00, 0x00, 0x0FE }; //Dallas sensor address
DHT dht(DHTPIN, DHTTYPE); //define the dht instance
LiquidCrystal lcd(2, 3, 4, 5, 6, 7); //LCD pins
boolean ButtonPushed = 0;
float temperature = 0;
int humidity = 0;
float dew = 0;
float ota = 0;
int read_button = 0;
boolean menus = 0; //case for menus
byte lcd_brightness; //starting amount of brightness for lcd the will be read form EEPROM
int fadeAmount = 5; //amount of lcd fading
int reading = 0; //initial reading for analog buttons
const int HeaterPin = 10; //FET pin No.
const int Buzzer = 11; //buzzer pin
const int backlightPin = 13; //LCD backlight dim pin
byte newChar[8] = {
  B00110,
  B01001,
  B01001,
  B00110,
  B00000,
  B00000,
  B00000,
  B00000};
void setup(){
  Serial.begin(9600); //used for debugging
  //while(!Serial);   //whether it is in comment brackets or active this command does nothing
  Wire.begin(); //initialize I2C bus
  delay(15);  //delay to make sure the EEPROM is initialized
  pinMode(HeaterPin, OUTPUT); //mode of FET pin
  pinMode(Buzzer, OUTPUT); // Mode of buzzer pin
  pinMode(backlightPin, OUTPUT); // pinmode for lcd pin
  lcd_brightness=(eepromRead(0,0),DEC); //read value from EEPROM
  // Serial.println(lcd_brightness);
  lcd.begin(20, 4); //initialize 20 char 4 line lcd
  lcd.createChar(0, newChar);
  lcd.setCursor(0,0);
  //---opening test text---
  analogWrite(backlightPin, lcd_brightness);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Kostas Dew Buster");
  lcd.setCursor(0,1);
  lcd.print("Version 0.15");
  lcd.setCursor(0,2);
  lcd.print("Test Build 0.5");
  lcd.setCursor(0,3);
  lcd.print("====================");
  delay(5000);
  lcd.clear();
  //---initialize sensors---
  dht.begin();
  sensors.begin();
  sensors.setResolution(HeaterTemp, 9); //set resolution of Dallas sensor to 9 bits i.e. 0,5C
byte eepromRead(byte highAddress, byte lowAddress)
  Wire.beginTransmission(EEPROM_ADDRESS);
  Wire.write(highAddress);
  Wire.write(lowAddress);
  Wire.endTransmission();
  Wire.requestFrom(EEPROM_ADDRESS,1);          //request one byte of data from eeprom at address 0x50
  while(!Wire.available())
  return Wire.read();
You may want to have a look at this thread, basically there are some pin conflicts in wire.h and liquidcrystal.h
http://forum.arduino.cc/index.php?topic=172748.0
BackWoodsBrewer:
The conflict is not really in Wire or LiquidCrystal but
rather the conflict is user error in the sketch.
The sketch has inadvertently configured Wire and LiquidCrystal to use the same AVR pins.
Have a look at the pinout diagram in this thread:
http://forum.arduino.cc/index.php?topic=148308.0
It shows which physical pin on the AVR chip that is connected
to each Arduino header pin.
Notice that SCL is physically connected to AVR pin 18 (PD0) which is also conected to Arduino digital pin 2
and SDA is physically connected to AVR pin 19 (PD1) which is also connected to Arduino digital pin 3
So while Arduino digital pin 2 and 3 are different Arduino pins from SCL and SDA,
on a leonardo board they are connected to the same AVR pins.
That means that you can't use Arduino digital pins 2 & 3 when using i2c on Leonardo.
--- bill
An alternative would be to get an i2c lcd backpack which would also free up
Arduino digital pins 4,5,6 & 7.
Note that you would loose the ability to dim the backlight as the i2c backpacks
can only turn the backlight on/off.
--- bill
thanks for the input, i changed the buzzer and placed it at the analog pin A1, so that left me with two digital pins free (i had one digital pin free on my board) in order to move all the other pins and not have the conflict of the lcd and the i2c libraries
