Read & Write Time Picker upsets Dashboard
Hello!
I have a project where I have a cloud variable of type CloudTime displayed in a Time Picker widget. In my sketch I set the variable by use of the ArduinoCloud.getLocalTime() function and in the dashboard it displays my local time (Central European) as it should.
I then notised that if my board (Arduino Nano 33 IoT) was reset the time variable was reset back to zero (displayed as start of Unix time i.e. 1970 something). I did not want that behavior but rather have the variable survive a possible restart. Since my board does not have any EEPROM and I do not want to use flash memory due to its limited number of write operations I instead though that I could make my cloud variable persistent by setting it Read & Write, instead of Read Only which had been the case so far. I did not intend to enter any time value through the widget, but just make it Read & Write so that the IoT Cloud should make it survive a restart. But that led to two new problems:
  1. In dashboards displayed in the IoT app (e.g. on my mobile phone and iPad) the widget now displayed GMT instead of local time.
  2. In the "Cloud Editor" on my PC the dashboard could no longer be displayed or edited at all. The dashboard starts to display but reverts to a blank screen before any widgets appear.
If I go into Things and change the Time Picker widget back to Read Only both dashboard problems go away again. Very consistent and repeatable.
I have now given up the idea of making the time value survive a restart (at least for the time being) but thought I would bring the problem up anyway, in case someone cares to look into it.
Cheers,
Lennart
