Read/Write to an attached SD card reader using a Nano RP2040 Connect
I am trying to get a SD card reader to work from an Arduino Nano RP2040 Connect. The code keeps failing.
The process actually fails here, and I am now using
const int= 10;
Fails here :-
Serial.print("Initializing SD card...");
if(!SD.begin(10))
Serial.println("initialization failed!");
while(1);
Serial.println("initialization done.");
SD.begin(10) never completes, so the 'if condition' is then true with 'while(1);' preventing the code from progressing any further.
The issue arises in 'SD.begin(cs_pin)' , where I have set cs_pin as follows :
const int cs_pin= 10;
Can you help me ?
Do I have to look inside the 'SD' library code ?
how is it wired?
is SD card inserted?
HI @anon68427626,
welcome to the arduino-forum.
You read the "how to get the best out of this forum" posting
The most important thing is to post your complete sketch as a code-section
inside the arduino-IDE:
press ctrl-t for autoformatting your code.
press ctrl-shift-C to copy the complete sketch into the clipboard
including the code-section formatting
change from IDE to browser and press ctrl-v
The reference to the RP2040 shows what IO-pins are used for the SPI-bus
best regards Stefan
