Hello everyone relative noob here. I'm currently trying to use the Adafruit ADS1015 library with a ads1114. I had the single ended read working a few days ago however its no longer working and readADC_SingleEnded locks the loop(). I'm actually using a msp430g2553 with energia, but that doesnt explain why it worked before and no longer does. Has this ever happened to anyone else before?
Here is my code.
#include <Wire.h>
#include <Adafruit_ADS1015.h>
//Adafruit_ADS1115 ads; /* Use this for the 16-bit version */
float voltage = 0.0;
void setup(void)
Serial.println("Hello!");
Serial.println("Getting single-ended readings from AIN0..3");
Serial.println("ADC Range: +/- 6.144V (1 bit = 3mV/ADS1015, 0.1875mV/ADS1115)");
// The ADC input range (or gain) can be changed via the following
// functions, but be careful never to exceed VDD +0.3V max, or to
// exceed the upper and lower limits if you adjust the input range!
// Setting these values incorrectly may destroy your ADC!
// ADS1015 ADS1115
// ads.setGain(GAIN_TWOTHIRDS); // 2/3x gain +/- 6.144V 1 bit = 3mV 0.1875mV (default)
// ads.setGain(GAIN_ONE); // 1x gain +/- 4.096V 1 bit = 2mV 0.125mV
// ads.setGain(GAIN_TWO); // 2x gain +/- 2.048V 1 bit = 1mV 0.0625mV
// ads.setGain(GAIN_FOUR); // 4x gain +/- 1.024V 1 bit = 0.5mV 0.03125mV
// ads.setGain(GAIN_EIGHT); // 8x gain +/- 0.512V 1 bit = 0.25mV 0.015625mV
// ads.setGain(GAIN_SIXTEEN); // 16x gain +/- 0.256V 1 bit = 0.125mV 0.0078125mV
Wire.begin();
void loop(void)
int16_t adc0;
// adc1, adc2, adc3;
Serial.print("AIN0: "); Serial.println(adc0);
adc0 = readADC_SingleEnded(0);
voltage = (adc0 * 0.1875)/1000;
Serial.print("\tVoltage: ");
Serial.println(voltage, 7);
Serial.println(" ");
delay(200);
uint8_t m_i2cAddress=0x48;
uint8_t m_conversionDelay=8;
uint8_t m_bitShift=0;
adsGain_t m_gain;
int16_t readADC_SingleEnded(uint8_t channel) {
// Start with default values
uint16_t config = ADS1015_REG_CONFIG_CQUE_NONE | // Disable the comparator (default val)
ADS1015_REG_CONFIG_CLAT_NONLAT | // Non-latching (default val)
ADS1015_REG_CONFIG_CPOL_ACTVLOW | // Alert/Rdy active low (default val)
ADS1015_REG_CONFIG_CMODE_TRAD | // Traditional comparator (default val)
ADS1015_REG_CONFIG_DR_1600SPS | // 1600 samples per second (default)
ADS1015_REG_CONFIG_MODE_SINGLE;
// Set PGA/voltage range
config |= m_gain;
Serial.println("Config is set ");
// Set single-ended input channel
switch (channel)
case (0):
config |= ADS1015_REG_CONFIG_MUX_SINGLE_0;
case (1):
config |= ADS1015_REG_CONFIG_MUX_SINGLE_1;
case (2):
config |= ADS1015_REG_CONFIG_MUX_SINGLE_2;
case (3):
config |= ADS1015_REG_CONFIG_MUX_SINGLE_3;
// Set 'start single-conversion' bit
config |= 0x8000;
Serial.println("Single conversion bit set");
// Write config register to the ADC
writeRegister(m_i2cAddress, ADS1015_REG_POINTER_CONFIG, config);
Serial.println("register has been written");
// Wait for the conversion to complete
delay(m_conversionDelay);
Serial.println("conversion delay is over");
// Read the conversion results
// Shift 12-bit results right 4 bits for the ADS1015
Serial.println("Returning the registers read");
return readRegister(m_i2cAddress, 0x00) >> m_bitShift;
byte test;
static void writeRegister(uint8_t i2cAddress, uint8_t reg, uint16_t value) {
Serial.println("Beginning i2c transmission");
Wire.beginTransmission(i2cAddress);
Serial.println("Writing to register");
Wire.write((uint8_t)reg);
Serial.println("Writting 8 bit shift");
Wire.write((uint8_t)(value>>8));
Serial.println("writing end value");
Wire.write((uint8_t)(value & 0xFF));
Serial.println("End of transmission");
test = Wire.endTransmission(true);
Serial.println(test);
int16_t readRegister(uint8_t i2cAddress, uint8_t reg) {
Serial.println("Reading from register");
Wire.write((uint8_t)0x00);
Wire.endTransmission();
Serial.println("requesting from i2c the registers read");
Wire.requestFrom(i2cAddress, (uint8_t)2);
return ((Wire.read() << 8) | Wire.read());
So it turns out there's an error with Wire.endTransmission(); although I'm not sure why. Any help with that would be awesome.
Thanks.
