Hello,
I want to use the example to control the birghtness of 3 LEDs. The code is here:
Reading a serial ASCII-encoded string.
This sketch demonstrates the Serial parseInt() function.
It looks for an ASCII string of comma-separated values.
It parses them into ints, and uses those to fade an RGB LED.
Circuit: Common-anode RGB LED wired like so:
* Red cathode: digital pin 3
* Green cathode: digital pin 5
* blue cathode: digital pin 6
* anode: +5V
created 13 Apr 2012
by Tom Igoe
This example code is in the public domain.
// pins for the LEDs:
const int redPin = 3;
const int greenPin = 5;
const int bluePin = 6;
// initialize serial:
// make the pins outputs:
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
// if there's any serial available, read it:
while (Serial.available() > 0) {
// look for the next valid integer in the incoming serial stream:
int red = Serial.parseInt();
// do it again:
int green = Serial.parseInt();
// do it again:
int blue = Serial.parseInt();
// look for the newline. That's the end of your
// sentence:
if (Serial.read() == '\n') {
// constrain the values to 0 - 255 and invert
// if you're using a common-cathode LED, just use "constrain(color, 0, 255);"
red = 255 - constrain(red, 0, 255);
green = 255 - constrain(green, 0, 255);
blue = 255 - constrain(blue, 0, 255);
// fade the red, green, and blue legs of the LED:
analogWrite(redPin, red);
analogWrite(greenPin, green);
analogWrite(bluePin, blue);
// print the three numbers in one string as hexadecimal:
Serial.print(red, HEX);
Serial.print(green, HEX);
Serial.println(blue, HEX);
As the example in http://arduino.cc/en/Tutorial/ReadASCIIString says I should enter sth. like 5,220,70 to give an analog write function to drive LEDS. After I've done sending these numbers, there was no responded back and the 3 LEDs was always shine at their full power even I entered 0,0,0.
For the circuit, I connect pin 3,5,6 to each 3 resistors seperately and series the resistors to each LEDs' cathode. Each LEDs' anode are common which are connected to 5V.
Why there was nothing happen? Is there any update about the example
Thank you
BlackMelon
